Home » Modeling » EMF » Is there a known vulnerability with concurrent calls to ResourceSetImpl.add(Resource)?
Is there a known vulnerability with concurrent calls to ResourceSetImpl.add(Resource)? [message #1518534] |
Sat, 20 December 2014 00:06  |
Until recently, we haven't had to register dynamic metamodels in our Eclipse IDE for QVTO development. We could instead register metamodels via their implementations. As far as using the Eclipse IDE to compile source *.qvto files into executable *.qvtox files, the Eclipse QVTO compiler only cares that all metamodels involved have been properly registered. Using the implementations was the simplest way to go. This worked very well for us for several years until now...
Now, we have to deal with fundamentally different versions of metamodels (UML 2.4 and UML 2.5) both of which have dependencies on the same metamodels. The conventional approach would lead to nasty jar conflicts. To be fair, these different versions are not designed to coexist in the same JVM! Since for Eclipse QVTO development we don't technically need to "execute" the metamodel, I thought that I could instead register all of these metamodels as dynamic -- i.e., *.ecore, no java.
In principle it should work (It's been described in several places, including the EMF book). However, I've encountered some problems at Eclipse initialization.
I'm using Eclipse Luna with a lot of EMF-related technology (XCore, QVTO, DiffMerge, EASE, ....) Too much to extract a simple test case but I think the problem is fairly simple.
Basically, there are multiple Eclipse views that, at startup, query the EMF EPackage registry. In the stack traces below, there are 2 views involved:
- the Eclipse QVTO Metamodel Registry view (it shows all the registered metamodels)
- an Eclipse QVTO editor (which makes references to several registered metamodels)
Both initializations trigger NPEs.
Daemon Thread [org.eclipse.m2m.internal.qvt.oml.editor.ui.QvtReconciler] (Suspended (exception NullPointerException))
owns: XcoreResource (id=113)
XcoreJavaProjectProvider.getJavaProject(ResourceSet) line: 97
XcoreJavaProjectProvider.getClassLoader(ResourceSet) line: 124
XcoreEcoreBuilder.getEPackage(XPackage) line: 195
XcoreModelAssociator.installDerivedState(DerivedStateAwareResource, boolean) line: 92
XcoreResource(DerivedStateAwareResource).installDerivedState(boolean) line: 159
XcoreResource(BatchLinkableResource).getContents() line: 133
RegistryReader$EPackageDescriptor$Dynamic.getEPackage() line: 251
EmfMetamodelDesc.getModel() line: 61
EmfMetamodelDesc.getLoadStatus() line: 91
MetamodelRegistry.toEPackageRegistry() line: 95
CompilerUtils.getEPackageRegistry(URI, IMetamodelRegistryProvider) line: 107
QVTOCompiler.getEPackageRegistry(URI) line: 529
QVTOCompiler.parse(UnitProxy, QvtCompilerOptions) line: 233
QVTOCompiler.doCompile(UnitProxy, QvtCompilerOptions, Monitor) line: 369
QVTOCompiler.compileSingleFile(UnitProxy, QvtCompilerOptions, Monitor) line: 326
QVTOCompiler.compile(UnitProxy[], QvtCompilerOptions, Monitor) line: 211
QVTOCompiler.compile(UnitProxy, QvtCompilerOptions, Monitor) line: 224
QvtCompilerFacade.compile(ITextEditor, IDocument, QvtCompilerOptions, IProgressMonitor) line: 77
QvtReconcilingStrategy.getCompilationResult(boolean) line: 90
QvtReconcilingStrategy.reconcileInternal() line: 74
QvtReconcilingStrategy.initialReconcile() line: 62
QvtReconciler(MonoReconciler).initialProcess() line: 105
AbstractReconciler$BackgroundThread.run() line: 173
The Eclipse QVTO Metamodel Registry view:
Thread [main] (Suspended (exception NullPointerException))
owns: XcoreResource (id=106)
MetamodelBrowserView$3(MetamodelBrowser).doCreateInput() line: 502
MetamodelBrowser$5.run() line: 473
BusyIndicator.showWhile(Display, Runnable) line: 70
MetamodelBrowserView$3(MetamodelBrowser).createInput() line: 471
MetamodelBrowserView$3(MetamodelBrowser).<init>(Composite, int) line: 168
MetamodelBrowserView$3(MetamodelBrowser).<init>(Composite) line: 145
MetamodelBrowserView$3.<init>(MetamodelBrowserView, Composite) line: 108
MetamodelBrowserView.createPartControl(Composite) line: 108
CompatibilityView(CompatibilityPart).createPartControl(IWorkbenchPart, Composite) line: 141
CompatibilityView.createPartControl(IWorkbenchPart, Composite) line: 155
CompatibilityView(CompatibilityPart).create() line: 327
NativeMethodAccessorImpl.invoke0(Method, Object, Object[]) line: not available [native method]
NativeMethodAccessorImpl.invoke(Object, Object[]) line: 62
DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: 43
Method.invoke(Object, Object...) line: 483
MethodRequestor.execute() line: 55
InjectorImpl.processAnnotated(Class<Annotation>, Object, Class<?>, PrimaryObjectSupplier, PrimaryObjectSupplier, ArrayList<Class<?>>) line: 888
InjectorImpl.processAnnotated(Class<Annotation>, Object, Class<?>, PrimaryObjectSupplier, PrimaryObjectSupplier, ArrayList<Class<?>>) line: 869
InjectorImpl.inject(Object, PrimaryObjectSupplier, PrimaryObjectSupplier) line: 120
InjectorImpl.internalMake(Class<?>, PrimaryObjectSupplier, PrimaryObjectSupplier) line: 337
InjectorImpl.make(Class<T>, PrimaryObjectSupplier) line: 258
ContextInjectionFactory.make(Class<T>, IEclipseContext) line: 162
ReflectionContributionFactory.createFromBundle(Bundle, IEclipseContext, IEclipseContext, URI) line: 104
ReflectionContributionFactory.doCreate(String, IEclipseContext, IEclipseContext) line: 73
ReflectionContributionFactory.create(String, IEclipseContext) line: 55
ContributedPartRenderer.createWidget(MUIElement, Object) line: 127
PartRenderingEngine.createWidget(MUIElement, Object) line: 983
PartRenderingEngine.safeCreateGui(MUIElement, Object, IEclipseContext) line: 662
PartRenderingEngine$6.run() line: 547
SafeRunner.run(ISafeRunnable) line: 42
PartRenderingEngine.createGui(MUIElement, Object, IEclipseContext) line: 531
ElementReferenceRenderer.createWidget(MUIElement, Object) line: 69
PartRenderingEngine.safeCreateGui(MUIElement) line: 766
PartRenderingEngine.access$2(PartRenderingEngine, MUIElement) line: 737
PartRenderingEngine$7.run() line: 731
PartRenderingEngine.createGui(MUIElement) line: 715
StackRenderer.showTab(MUIElement) line: 1250
StackRenderer(LazyStackRenderer).postProcess(MUIElement) line: 100
PartRenderingEngine.safeCreateGui(MUIElement, Object, IEclipseContext) line: 678
SashRenderer(SWTPartRenderer).processContents(MElementContainer<MUIElement>) line: 68
SashRenderer.processContents(MElementContainer<MUIElement>) line: 185
PartRenderingEngine.safeCreateGui(MUIElement, Object, IEclipseContext) line: 674
PerspectiveRenderer(SWTPartRenderer).processContents(MElementContainer<MUIElement>) line: 68
PerspectiveRenderer.processContents(MElementContainer<MUIElement>) line: 49
PerspectiveStackRenderer.showTab(MUIElement) line: 103
PerspectiveStackRenderer(LazyStackRenderer).postProcess(MUIElement) line: 100
PerspectiveStackRenderer.postProcess(MUIElement) line: 77
WBWRenderer(SWTPartRenderer).processContents(MElementContainer<MUIElement>) line: 68
WBWRenderer.processContents(MElementContainer<MUIElement>) line: 664
PartRenderingEngine$9.run() line: 1078
Realm.runWithDefault(Realm, Runnable) line: 332
PartRenderingEngine.run(MApplicationElement, IEclipseContext) line: 1032
E4Workbench.createAndRunUI(MApplicationElement) line: 148
Workbench$5.run() line: 636
Workbench.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 579
PlatformUI.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 150
IDEApplication.start(IApplicationContext) line: 135
EclipseAppHandle.run(Object) line: 196
EclipseAppLauncher.runApplication(Object) line: 134
EclipseAppLauncher.start(Object) line: 104
EclipseStarter.run(Object) line: 380
EclipseStarter.run(String[], Runnable) line: 235
Main.invokeFramework(String[], URL[]) line: 648
Main.basicRun(String[]) line: 603
Main.run(String[]) line: 1465
Main.main(String[]) line: 1438
These 2 threads are trying to register the same EPackage: xcore.lang
The NPE is caused by the fact that the ResourceSet's resources contains a NULL!
for (Resource resource : resourceSet.getResources())
URI uri = resource.getURI(); // NPE because resource is null!
There was a misleading NPE that turns out to be a minor vulnerability in the EMF RegistryReader:
diff --git a/plugins/org.eclipse.emf.ecore/src/org/eclipse/emf/ecore/plugin/RegistryReader.java b/plugins/org.eclipse.emf.ecore/src/org/eclipse/emf/ecore/plugin/RegistryReader.java
index 9666a50..bf098c3 100644
--- a/plugins/org.eclipse.emf.ecore/src/org/eclipse/emf/ecore/plugin/RegistryReader.java
+++ b/plugins/org.eclipse.emf.ecore/src/org/eclipse/emf/ecore/plugin/RegistryReader.java
@@ -24,9 +24,11 @@ import org.eclipse.core.runtime.IExtensionRegistry;
import org.eclipse.core.runtime.IRegistryChangeEvent;
import org.eclipse.core.runtime.IRegistryChangeListener;
import org.eclipse.emf.common.CommonPlugin;
+import org.eclipse.emf.common.util.EList;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.common.util.WrappedException;
import org.eclipse.emf.ecore.EFactory;
+import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.EPackage;
import org.eclipse.emf.ecore.EcorePackage;
import org.eclipse.emf.ecore.resource.Resource;
@@ -244,7 +246,11 @@ public abstract class RegistryReader
else
- return (EPackage) EcoreUtil.getObjectByType(resourceSet.getResource(locationURI, true).getContents(), EcorePackage.Literals.EPACKAGE);
+ Resource r = resourceSet.getResource(locationURI, true);
+ if (r != null)
+ return (EPackage) EcoreUtil.getObjectByType(r.getContents(), EcorePackage.Literals.EPACKAGE);
+ else
+ throw new RuntimeException("No EPackage found at: " + locationURI);
else
Basically, the original code assumes that resourceSet.getResource(...) never returns null. AFAIK, there is no such guarantee at the point in the logic.
With this NPE vulnerability aside, we are left with the problem: how could a ResourceSet have a null resource?
This should not happen but it obviously does in this case.
The problem is really due to concurrent calls to ResourceSet.add(Resource) because
the default implementation (i.e. ResourceSetImpl) is not thread-safe for concurrent modification.
I managed to work around the problem by synchronizing calls to ResourceSetImpl::add(Resource):
diff --git a/plugins/org.eclipse.emf.ecore/src/org/eclipse/emf/ecore/resource/impl/ResourceSetImpl.java b/plugins/org.eclipse.emf.ecore/src/org/eclipse/emf/ecore/resource/impl/ResourceSetImpl.java
index 6f896e8..9792542 100644
--- a/plugins/org.eclipse.emf.ecore/src/org/eclipse/emf/ecore/resource/impl/ResourceSetImpl.java
+++ b/plugins/org.eclipse.emf.ecore/src/org/eclipse/emf/ecore/resource/impl/ResourceSetImpl.java
@@ -432,7 +432,9 @@ public class ResourceSetImpl extends NotifierImpl implements ResourceSet
if (resourceFactory != null)
Resource result = resourceFactory.createResource(uri);
- getResources().add(result);
+ if (result != null) {
+ getResources().add(result);
return result;
else
@@ -609,6 +611,14 @@ public class ResourceSetImpl extends NotifierImpl implements ResourceSet
return size <= 4 ? super.contains(object) : object instanceof Resource && ((Resource)object).getResourceSet() == ResourceSetImpl.this;
+ @Override
+ public boolean add(E object) {
+ synchronized(this) {
+ return super.add(object);
The evidence that this workaround is effective is that if I comment out the synchronized guard in the call to super.add(object), then I get NPEs on 2 threads at initialization.
Has anyone encountered this problem before?
Is there a test case that involves plugins that register dynamic metamodels?
If yes, I'd like to see if I can reproduce this problem in a simpler environment by opening the Eclipse QVTO metamodel registry view and an Eclipse QVTO editor.
This seems to be enough to concurrent threads that will initialize the EMF EPackage registry and therefore force adding metamodel resources to the same ResourceSet.
On the other hand, it is rather interesting that these NPEs have systematically happened during the initialization of XCore even though the examples I made do not involve XCore's metamodels (except for the Eclipse QVTO Metamodel Registry view which shows all registered metamodels -- static & dynamic)
- Nicolas.
Re: Is there a known vulnerability with concurrent calls to ResourceSetImpl.add(Resource)? [message #1518882 is a reply to message #1518534] |
Sat, 20 December 2014 04:52   |
Nicolas,
Comments below.
> no java.
> views involved:
> metamodels)
> Daemon Thread
> line: 92
> line: 159
> line: 107
> line: 369
> Monitor) line: 326
> line: 211
> 224
> line: 92
> line: 159
> line: 168
> line: 108
> line: 155
> line: 888
> line: 869
> line: 55
> line: 531
> line: 737
> line: 737
> line: 68
> line: 737
> line: 68
> line: 737
> line: 68
> line: 737
> line: 68
> line: 49
> line: 737
> 100
> line: 737
> line: 68
> line: 737
> line: 68
> line: 737
> line: 1032
> contains a NULL!
> diff --git
> else
> - return (EPackage)
> + if (r != null)
> + return (EPackage)
> + else
> " + locationURI);
> else
> the logic.
This sounds more likely to be a problem with no resource factory being
registered for *.xcore. https://bugs.eclipse.org/bugs/show_bug.cgi?id=453329
> ResourceSet.add(Resource) because the default implementation (i.e.
No, resource sets aren't designed or intended to be thread safe and
adding synchronization will be a source of deadlock. Better to look at
something like
org.eclipse.emf.ecore.plugin.RegistryReader.EPackageDescriptor.Dynamic.getEPackage()
and make sure that it hold a lock on the resource set rather than start
sprinkling synchronization into all resource set implementations.
> diff --git
> return result;
> else
> + @Override
No.
> metamodels?
No.
We'd need a new test case, but it's pretty clear from inspection that
isn't thread safe.
Yes, that's a little odd. I do get the sense that something
(MetamodelRegistry.toEPackageRegistry()?) is aggressively loading all
registered models.
> - Nicolas.
Re: Is there a known vulnerability with concurrent calls to ResourceSetImpl.add(Resource)? [message #1518908 is a reply to message #1518534] |
Sat, 20 December 2014 05:10   |
Hi Nicolas
EMF has a very sensible thread safety policy: [1]
"EMF can safely be used in multi-threaded environments; however, EMF
does not, itself, ensure thread-safety in application model
implementations. Data structures are unsynchronized, for performance and
to avoid potential deadlock situations. The expectation is that a
complete instance of the model (including resources and resource set, if
present) should only be accessed by one thread at a time, and that the
synchronization should be provided by the application at a higher level. "
This worked well for many years. Recently EMF UI tooling has been
improving with facilities such as live validation without full
consideration of the consequent elevation of EMF single-threaded tools
to the status of applications.
This is particularly serious for UML where profiles are loaded lazily.
Consequently what an EMF developer might consider to be a simple short
sharp activity is not simple at all since what appeared to be a trivial
eGet() might actually involve loading 10 UML models and a ResourceSet
modification. I have raised at least a couple of CME bugs that this
laziness has exposed.
This can be differently serious when OCL enrichment is used, since once
again a simple eGet() may involve OCL parsing, model loading and
evaluation of the relevant OCL delegate body.
There are a couple of recent bug fixes that mitigate these hazards.
Your problem seems slightly adjacent. At the simplest level, if you are
not using Xcore then why are Xcore resources being loaded? I vaguely
recall raising a QVTo bug to the effect that a registry scan was being
over-enthusiastic; it can easily cause all installed model plugins o be
activated.
I recommend investigating why QVTo is allowing Xcore to incur
non-trivial costs and identifying what the concurrent activities are and
why they are not synchronized. A few years ago a validation hazard was
resolved by synchronizing on the ResourceSet, but I am not aware of any
documentation to establish a more general inter-thread design approach.
Ed Willink
[1] https://wiki.eclipse.org/EMF/FAQ#Is_EMF_thread-safe.3F
> involved:
> metamodels)
> metamodels)
> boolean) line: 92
> line: 107
> line: 369
> Monitor) line: 326
> line: 211
> boolean) line: 92
> line: 168
> line: 108
> line: 155
> 888
> 869
> line: 531
> 737
> 737
> 737
> 737
> 737
> line: 49
> 737
> line: 100
> 737
> 737
> 737
> 1032
> a NULL!
> diff --git
> else
> - return (EPackage)
> + if (r != null)
> + return (EPackage)
> + else
> + locationURI);
> else
> the logic.
> diff --git
> return result;
> else
> + @Override
> metamodels?
> - Nicolas.
Re: Is there a known vulnerability with concurrent calls to ResourceSetImpl.add(Resource)? [message #1519740 is a reply to message #1518908] |
Sat, 20 December 2014 16:26   |
There seem to be several problems involved.
1) no resource factory registered for *.xcore
Jonas' last comment is definitely relevant since both QVTO's Metamodel Browser view and QVTO's Compiler do browse the EPackage registry for metamodels.
Added Ed for information, because this problem might affect other frameworks too, which browse the package registry.
How do I tell if this bug affects me?
The ResourceSet involved -- i.e.: org.eclipse.emf.ecore.plugin.RegistryReader.EPackageDescriptor.Dynamic.resourceSet -- does not have any resource factory.
I don't understand how having or not a resource factory for XCore.lang per se would have such a particular impact on a small fraction of completely unrelated metamodels!
This bug may be a factor but it seems that it's not enough.
There must be something else involved.
2) vulnerability to NPE
Shouldn't Eclipse initialize cleanly without any NPEs?
Since ResourceSet.getResource() may return null, the code in org.eclipse.emf.ecore.plugin.RegistryReader.EPackageDescriptor.Dynamic.getEPackage()
will trip an NPE in precisely such case:
I really would like to see this fixed -- it's annoying to get these NPEs when launching Eclispe under the debugger.
Is this enough to cause the problems? Again, it may be a symptom but it does not seem to be sufficient by itself.
3) concurrency problems.
> something like
I don't understand.
If resource sets are not designed nor intended to be thread safe, then doesn't this imply that there should be at most 1 thread modifying a given resource set at any time?
If it does, then why would adding synchronization using the resource set itself be a source of deadlock?
In examining the code involved in the stack trace, I noticed that there is in fact synchronization in a different method:
org.eclipse.xtext.xbase.resource.BatchLinkableResource.getContents():
public EList<EObject> getContents() {
synchronized (getLock()) {
if (isLoaded && !isLoading && !isInitializing && !isUpdating && !fullyInitialized) {
try {
eSetDeliver(false);
installDerivedState(false);
} finally {
eSetDeliver(true);
return doGetContents();
In this case -- i.e., the resource set is: org.eclipse.emf.ecore.plugin.RegistryReader.EPackageDescriptor.Dynamic.resourceSet
Since it isn't an ISynchronizable, getLock() returns 'this' -- i.e. the resource itself.
* Returns the lock of the owning {@link ResourceSet}, if it exposes such a lock.
* Otherwise this resource itself is used as the lock context.
/* @NonNull */
public Object getLock() {
ResourceSet resourceSet = getResourceSet();
if (resourceSet instanceof ISynchronizable<?>) {
return ((ISynchronizable<?>) resourceSet).getLock();
return this;
What happens then?
Well, we can have multiple threads that will concurrently attempt to initialize XCore's metamodels but with *different* Resource objects -- i.e. different Resources loaded from uri='platform:/plugin/org.eclipse.emf.ecore.xcore.lib/model/XcoreLang.xcore'
Here are some examples:
Daemon Thread [org.eclipse.m2m.internal.qvt.oml.editor.ui.QvtReconciler] (Suspended)
owns: XcoreResource (id=172)
XcoreResource(BatchLinkableResource).getContents() line: 130
XcoreResource(XtextResource).updateInternalState(IParseResult) line: 253
XcoreResource(DerivedStateAwareResource).updateInternalState(IParseResult) line: 101
XcoreResource(XtextResource).updateInternalState(IParseResult, IParseResult) line: 248
XcoreResource(DerivedStateAwareResource).updateInternalState(IParseResult, IParseResult) line: 93
XcoreResource(XtextResource).doLoad(InputStream, Map<?,?>) line: 161
XcoreResource(LazyLinkingResource).doLoad(InputStream, Map<?,?>) line: 100
XcoreResource(ResourceImpl).load(InputStream, Map<?,?>) line: 1518
XcoreResource(ResourceImpl).load(Map<?,?>) line: 1297
RegistryReader$EPackageDescriptor$Dynamic$1(ResourceSetImpl).demandLoad(Resource) line: 259
RegistryReader$EPackageDescriptor$Dynamic$1(ResourceSetImpl).demandLoadHelper(Resource) line: 274
RegistryReader$EPackageDescriptor$Dynamic$1(ResourceSetImpl).getResource(URI, boolean) line: 406
RegistryReader$EPackageDescriptor$Dynamic.getEPackage() line: 249
and:
owns: XcoreResource (id=186)
and:
owns: XcoreResource (id=190)
and:
Thread [main] (Suspended)
owns: XcoreResource (id=126)
Even though I stopped all of these threads, the RegistryReader's ResourceSet is already compromised:
resourceSet org.eclipse.emf.ecore.plugin.RegistryReader$EPackageDescriptor$Dynamic$1 (id=128)
org.eclipse.emf.ecore.plugin.RegistryReader$EPackageDescriptor$Dynamic$1@50ad5eb8 resources=[org.eclipse.emf.ecore.xcore.resource.XcoreResource@e11cb3b uri='platform:/plugin/org.eclipse.emf.ecore.xcore.lib/model/XcoreLang.xcore', null, null, org.eclipse.emf.ecore.xcore.resource.XcoreResource@6e716c17 uri='platform:/plugin/org.eclipse.emf.ecore.xcore.lib/model/XcoreLang.xcore']
There are already 2 null values and XcoreLang appears twice already!
Even though it may not be the best way to fix the problem, it's interesting that adding a synchronization on ResourceSetImpl.add(Resource) suffices to avoid this problem (it could cause others as Ed M pointed out).
- Nicolas.
Re: Is there a known vulnerability with concurrent calls to ResourceSetImpl.add(Resource)? [message #1519861 is a reply to message #1519740] |
Sat, 20 December 2014 18:02   |
As Ed M observed, adding synchronization to ResourceSetImple.add(Resource)
would have wide ranging impacts. Instead, I added synchronization
to the mutating operations of RegistryReader's dynamic resourceSet class.
Based on limited tests, this seems to work fine; at least, I don't get any NPEs on Eclipse startup and the EPackage registry doesn't have any errors.
index 9666a50..23b4c26 100644
@@ -202,7 +204,17 @@ public abstract class RegistryReader
protected Set<URI> uris = new HashSet<URI>();
- protected Resource delegatedGetResource(URI uri, boolean loadOnDemand)
+ public synchronized Resource getResource(URI uri, boolean loadOnDemand) {
+ return super.getResource(uri, loadOnDemand);
+ @Override
+ public synchronized Resource createResource(URI uri, String contentType) {
+ return super.createResource(uri, contentType);
+ @Override
+ protected synchronized Resource delegatedGetResource(URI uri, boolean loadOnDemand)
try
@@ -244,7 +256,11 @@ public abstract class RegistryReader
else
+ if (r != null)
+ else
else
index 6f896e8..7c76108 100644
return result;
else
- Nicolas.
Re: Is there a known vulnerability with concurrent calls to ResourceSetImpl.add(Resource)? [message #1520647 is a reply to message #1519740] |
Sun, 21 December 2014 04:49   |
Nicolas,
Comments below.
> metamodels.
That may be, but shouldn't those metamodels should be development time
models?
> Quote:
I guess you'd see the stack trace from that bugzilla.
Keeing in mind that the local resource set's resource factory delegates
to the global one...
If something loads all models in the registry aggressively, then it's
sort of irrelevant whether it's related to what you're doing on or not.
Of course.
Which we could ignore, but it is indicative of an underlying problem
which is best not to ignore.
> return (EPackage)
Generally bugs get fixed when they are reported with a suitable test
case. (And I'm not generally happy with bugs whose reproduction
including "install the following large stack of technology").
>> at something like
>> start sprinkling synchronization into all resource set implementations.
> I don't understand.
Yes.
Because the method you added it to calls what else, which calls what
else, which does what other kinds of locking and synchronization?
Goodness only knows, but what you're proposing is like going to
ArrayList and modifying the add method to be synchronized; it's just not
the intent of the ArrayList implement to be thread safe in this way.
> try {
> eSetDeliver(false);
> } finally {
> eSetDeliver(true);
In an Xtext resource; apparently you do have Xcore's resource factory
registered.
> /* @NonNull */
> return this;
> What happens then?
> Daemon Thread
> line: 253
> line: 101
> line: 100
> line: 259
> line: 274
> boolean) line: 406
> line: 107
> line: 369
> Monitor) line: 326
> line: 211
> 224
> and:
> Daemon Thread
> line: 253
> line: 101
> line: 100
> line: 259
> line: 274
> boolean) line: 406
> line: 107
> line: 369
> Monitor) line: 326
> line: 211
> 224
> and:
> Daemon Thread
> line: 253
> line: 101
> line: 100
> line: 259
> line: 274
> boolean) line: 406
> line: 107
> line: 369
> Monitor) line: 326
> line: 211
> 224
> and:
> line: 253
> line: 101
> line: 100
> line: 259
> line: 274
> boolean) line: 406
> line: 168
> line: 108
> line: 155
> line: 888
> line: 869
> line: 55
> line: 531
> line: 737
> line: 737
> line: 68
> line: 737
> line: 68
> line: 737
> line: 68
> line: 737
> line: 68
> line: 49
> line: 737
> 100
> line: 737
> line: 68
> line: 737
> line: 68
> line: 737
> line: 1032
> resourceSet
> (id=128)
> resources=[mailto:org.eclipse.emf.ecore.xcore.resource.XcoreResource@e11cb3b
> null, null,
> mailto:org.eclipse.emf.ecore.xcore.resource.XcoreResource@6e716c17
Yes, that can't be good.
Better to fix the problem specific to the use of the one resource set by
the dynamic package registry.
> - Nicolas.
Re: Is there a known vulnerability with concurrent calls to ResourceSetImpl.add(Resource)? [message #1522402 is a reply to message #1521754] |
Mon, 22 December 2014 04:36   |
Nicolas,
Comments below.
On 22/12/2014 1:54 AM, Nicolas Rouquette wrote:
> Ed,
> Quote:
>> resource > set itself be a source of deadlock?
>> not the intent of the ArrayList implement to be thread safe in this way.
>> > Even though it may not be the best way to fix the problem, it's >
>> interesting that adding a synchronization on >
>> could > cause others as Ed M pointed out).
>> by the dynamic package registry.
> Does the fix below correspond to your suggestion to fix the specific
> problem in the dynamic package registry?
No, that logic focuses on guarding the creation of a new resource, but
one most also consider the logic that simply finds a resource already in
the resource set while a second thread is creating a resource. Perhaps
the second thread will need to grow the underlying list while the first
thread is iterating over it. All access, both read and write, needs
guarding. That could be done by synchronizing on the resource set
rather than adding synchronize to specialized methods of the resource set.
Also, I see no need to check that a resource factory actually returns a
resource given that the list of resources itself is guarded to prevent
null from being added.
> https://www.eclipse.org/forums/index.php?t=msg&th=899781&goto=1519861&#msg_1519861
> - Nicolas.
Re: Is there a known vulnerability with concurrent calls to ResourceSetImpl.add(Resource)? [message #1524195 is a reply to message #1522949] |
Tue, 23 December 2014 04:25   |
Nicolas,
Comments below.
On 22/12/2014 6:15 PM, Nicolas Rouquette wrote:
> Ed,
> Ed Merks wrote on Mon, 22 December 2014 09:36
>> specific > problem in the dynamic package registry?
>> but one most also consider the logic that simply finds a resource
>> already in the resource set while a second thread is creating a
>> resource. Perhaps the second thread will need to grow the underlying
>> list while the first thread is iterating over it. All access, both
>> read and write, needs guarding. That could be done by synchronizing
>> on the resource set rather than adding synchronize to specialized
> Is that enough?
> Synchronizing access to the ResourceSet does not guarantee
> synchronized access to the list of Resources.
That's true, but this resource set
(org.eclipse.emf.ecore.plugin.RegistryReader.EPackageDescriptor.Dynamic.resourceSet)
is intended only for the purpose of loading/finding registered dynamic
packages so the only place its used is in
so it's sufficient that the use within that method be guarded. The
simplest way to do that is to make getEPackage itself synchronized, but
likely we can do something more fine-grained. We we don't need is to
try to make the whole resource set thread safe, because that's a losing
battle.
> Consider a typical use of the API:
> ResourceSet rs = ...;
> rs.getResources().add(...);
> Synchronizing access to rs will only serialize the calls to
> rs.getResources() but it won't guarantee serialization of the additions.
Exactly, and nothing will help with iteration, which is why Vector fell
out of favor and ArrayList is used instead.
> - Nicolas.
Re: Is there a known vulnerability with concurrent calls to ResourceSetImpl.add(Resource)? [message #1526947 is a reply to message #1524467] |
Wed, 24 December 2014 17:37   |
Ed Willink wrote on Tue, 23 December 2014 13:00
My suggestion is that you must
synchronized (rs) {
so that by acquiring arbitrated exclusive access to the ResourceSet you
acquire implied exclusive access to all its content too.
I doubt that this suggestion is sufficient.
Consider ResourceSetImpl.createResource:
public Resource createResource(URI uri, String contentType)
Resource.Factory resourceFactory = getResourceFactoryRegistry().getFactory(uri, contentType);
return result;
else
return null;
By your suggestion, this would have to be synchronized.
The ResourceSet mutex just acts as a token passed from thread to thread
identifying which thread is THE EMF thread that may may arbitrary changes.
Arbitrating access ONLY at the coarsest grain provides a reasonable
opportunity to avoid deadlocks. Framework code must NOT synchronize
since synchronization is an application responsibility.
But you exclude framework code; which means that callers of ResourceSet.createResource() would also have to be synchronized outside of framework code.
The problem here is that the ResourceSet API exposes the resources it manages as a mutable list.
Yet, it's clear now that we shouldn't have concurrent modification of that list.
I think that there are roughly 3 different strategies to address this problem:
Strategy1: keep the ResourceSet API as-is but add policies to ensure serialization of modification of a ResourceSet and of its managed Resources
It is difficult to identify how many policies are needed because the API "leaks" mutable state -- e.g., ResourceSet.getResources() -- so it expands the scope of objects we have to directly and indirectly synchronize access to.
Your suggestion is an example of such a policy but it is incomplete.
As Ed M observed, org.eclipse.emf.ecore.plugin.RegistryReader.EPackageDescriptor.Dynamic.getEPackage() isn't thread safe. This means its access would have to be covered somehow in a synchronization policy.
Even if someone could come up with a reasonable list of policies; this strategy would be particularly expensive to adopt
since it would require refactoring lots of EMF-based applications.
Strategy2: fix the ResourceSet API to prevent leaking mutable state
Currently, ResourceSet.getResources() returns a mutable list -- i.e., it leaks mutable state.
In this strategy, this API would be changed to return an immutable list instead and there
would be a new API to add a Resource to a ResourceSet.
This strategy would require some refactoring of EMF-based applications but not as much as the previous strategy.
Strategy3: manage the EMF EPackage registry in dedicated thread
This is a hybrid of the 2 with the difference that instead of imposing synchronization code on EMF-based applications,
there would be a dedicated EMF thread per each EMF EPackage registry and all of the related objects it involves
(e.g. the RegistryReader dynamic ResourceSet). For EMF client applications, the EMF EPackage registry API would look like it does today (except for refactoring API methods that leak state into a pair of a query/update API methods per strategy 2). These API methods would queue requests to the EMF EPackage registry thread which would ensure that all operations on the EPackage registry & related objects would be serialized. Some APIs would have to be refactored to include callback operations -- e.g. to enable loading EMF EPackages on the client's class loader instead of the the EMF EPackage registry thread's class loader.
What do you think?
- Nicolas.
Re: Is there a known vulnerability with concurrent calls to ResourceSetImpl.add(Resource)? [message #1529376 is a reply to message #1526947] |
Fri, 26 December 2014 03:00   |
Hi Nicolas
I am not suggesting that synchronizing the ResourceSet gives arbitrated
solution to all EMF accesses. A total solution would require fine
grained mutexes and be completely incompatible with the EMF design.
I am suggesting an agreed policy whereby each thread in a multithreaded
EMF application must acquire the ResourceSet mutex before doing any EMF
access on the ResourceSet. The ResourceSet mutex can be fully arbitrated.
Your example of ResourceSetImpl.createResource, like numerous EMF
routines, is not threadsafe. The solution is not to recode it, but to
follow my suggested policy. The thread in which
ResourceSetImpl.createResource is called is required to acquire the
ResourceSet mutex before calling ResourceSetImpl.createResource. The
solution is therefore pushed back to the original caller and so is a
'simple' application code adherence requiring no change at all to the
EMF framework.
Ed Willink
>> synchronized (rs) {
>> you acquire implied exclusive access to all its content too.
> return result;
> else
> return null;
> Quote:
>> thread identifying which thread is THE EMF thread that may may
>> arbitrary changes.
> of framework code.
> manages as a mutable list. Yet, it's clear now that we shouldn't have
> problem:
> As Ed M observed,
> instead and there would be a new API to add a Resource to a ResourceSet.
> What do you think?
> - Nicolas.
Re: Is there a known vulnerability with concurrent calls to ResourceSetImpl.add(Resource)? [message #1529709 is a reply to message #1526947] |
Fri, 26 December 2014 07:39   |
Nicolas,
As I said before, the specific problem you've pointed out is that
is not properly thread safe. That can be solved purely by making that
method thread safe, either by making the whole method synchronized, or
perhaps by doing something a little more fine-grained within the method
(e.g., synchronizing on the resource set before accessing it as Ed W has
suggested).
This discussion of trying to make ResourceSet itself thread safe is
simply a rat hole, and kind of pointless because I simply do no intend
to make any changes to synchronize a resource set's implementation. I
can pretty guarantee that any such approach will deadlock applications
that are already written with their own threading policy based on the
the assumption that there are no other locks involved.
>> synchronized (rs) {
> return result;
> else
> return null;
> Quote:
>> arbitrary changes.
> problem:
> Resources
> As Ed M observed,
> list instead and there would be a new API to add a Resource to a
> ResourceSet.
> What do you think?
> - Nicolas.
Re: Is there a known vulnerability with concurrent calls to ResourceSetImpl.add(Resource)? [message #1530963 is a reply to message #1529709] |
Sat, 27 December 2014 00:44   |
Ed Merks wrote on Fri, 26 December 2014 12:39Nicolas,
suggested).
This definitely works, thanks!
Ok
Ed M's suggestion is definitely a big help but there's something complicated going on involving several factors:
- the "per thread" initialization of EPackageImpl until initialization is completed
- the order in which the global EPackage registry is initialized (e.g. the Eclipse QVTO MetamodelBrowser viewer)
- variations in the code idioms with which java-based EPackage implementations are initialized using static variables
From an end-user point of view, a visible manifestation of a snafu is that the Eclipse QVTO compiler fails to compile something like this:
"p.ownedElement->selectByKind(uml::PackageableElement)"
There's an error like this:
Cannot find operation (selectByKind(PackageableElement)) neither for the type (Set(Element)) nor for its element type (Element)
"selectByKind" is a peculiar operation. It's not the typical variety of java-based EOperation implementation.
See: org.eclipse.ocl.ecore.internal.OCLStandardLibraryImpl.stdlibPackage (it is a static variable)
There's no ecore extension point registering the OCL StandardLibrary package per se (unlike Ecore, OCL/Types, OCL/Expressions/... )
Any suggestions?
- Nicolas.
Current Time: Thu Jul 24 23:04:08 EDT 2025
Powered by FUDForum. Page generated in 0.09805 seconds
