Home » Archived » BIRT » Birt output format
Birt output format [message #151356] Thu, 06 April 2006 05:05 Go to next message
Originally posted by: fabien_allanic.yahoo.fr
I'm searching for other BIRT output formats than PDF and HTML, especially
Microsoft Word one.
Have some plugins been developped? Does a BIRT equivalent exists for this
feature? Can you direct me on another project if BIRT definitively can't
implement this feature?
Thank you for your help!
Fabien Allanic
Re: Birt output format [message #151363 is a reply to message #151356] Thu, 06 April 2006 05:06 Go to previous messageGo to next message
Originally posted by: lazzeroni.voila.fr
you have export excel
Re: Birt output format [message #151385 is a reply to message #151363] Thu, 06 April 2006 07:12 Go to previous messageGo to next message
Thanks for the rapid answer!
It's possible with BIRT? I found nothing on it but I will continue
searching.
But I'm especially interessed in Word export, which is needed for my
project.
If someone has an indication...
thx
Fabien Allanic
Re: Birt output format [message #151394 is a reply to message #151385] Thu, 06 April 2006 07:34 Go to previous messageGo to next message
in birt you go in Web viewer and after you have an icon export dated
Re: Birt output format [message #151440 is a reply to message #151394] Thu, 06 April 2006 09:23 Go to previous messageGo to next message
I'm sorry but in BIRT I can only view my report in PDF or WEB view, not in
excel or other format :(
Re: Birt output format [message #151448 is a reply to message #151440] Thu, 06 April 2006 09:36 Go to previous messageGo to next message
you go in the veb viewer and after only you have the icon of right-hand
side which allows you to export
Re: Birt output format [message #151536 is a reply to message #151356] Thu, 06 April 2006 11:53 Go to previous messageGo to next message
Fabien,
I have been looking at this a little bit for a different project. One
of the possible routes to doing this would be to create a Word Emitter.
While not trivial, this is a task that could is very do-able. I have
included a link on a decent article for the creation of Word Docs from
XML.
http://idealliance.org/papers/dx_xmle04/papers/02-03-01/02-0 3-01.html
I think the ideas here are in line for one possible route to create a
BIRT Word Emitter. There would still be some work to do, but it is a
helpful start.
Scott Rosenbaum
BIRT PMC
Fabien Allanic wrote:
> especially Microsoft Word one.
> this feature? Can you direct me on another project if BIRT definitively
> can't implement this feature?
> Fabien Allanic
Re: Birt output format [message #151578 is a reply to message #151536] Thu, 06 April 2006 12:28 Go to previous messageGo to next message
Originally posted by: m.n.com
Are you suggesting the route they took (as discussed in that link)? If
so, this would be a Windows only solution because it requires Word to be
installed. I've done plenty of Office COM Api stuff and is very
problematic.
Scott Rosenbaum wrote:
> Fabien,
> included a link on a decent article for the creation of Word Docs from XML.
> helpful start.
> Scott Rosenbaum
> BIRT PMC
>> Hi,
>> definitively can't implement this feature?
>> Fabien Allanic
Re: Birt output format [message #151726 is a reply to message #151356] Fri, 07 April 2006 01:12 Go to previous messageGo to next message
Originally posted by: qauck.msn.com
Fabien,
For "doc" format, why not just open the html file in Word and choose
"save as..."->"(*.doc)"? Just let Micro$oft do what you want:).
For "xls" format, I've written an Xls emitter for BIRT. Currently it
supports BIRT 2.0 and 2.0.1. And I will release a new version once BIRT
2.1 is out. The new version will include some configurable settings such
as "show gridlines", "use fixed column width", etc. Please redirect to
my blog(http://qauck.blogspot.com) for more detail.
regards
Shawn
> Fabien Allanic
Re: Birt output format [message #151780 is a reply to message #151726] Fri, 07 April 2006 03:30 Go to previous message
Hi Shawn,
of course your idea is quite astute :), but my reports will be generated
automatically in word format, so I need a word emitter exactly like the
one you're developping for Excel :).
So I'll continue searching for project like yours, or maybe try jasper
reports which can export documents in RTF format (but it seems to not be
as easy and powerful as BIRT :s).
Thank you everybody, if you have others ideas you're welcome ;)
Fabien
Previous Topic:Urgent:Passing Design Object to Run/Render task & cacheing ???
Next Topic:Change a database connection or pass a dataset in a parameter
Current Time: Sun Nov 09 10:50:14 EST 2025
Powered by FUDForum. Page generated in 0.04570 seconds
