Home » Eclipse Projects » Oomph » How to un-import projects?
How to un-import projects? [message #1514801] Wed, 17 December 2014 11:19 Go to next message
Oomph 1.0.0.v20141217-0934 (build 709)
I can import projects easily using the Oomph Importer wizard. But how
can I un-import projects that I no longer need? Hitting the up-arrow
button removes a selection from the list at the bottom of the wizard
page if it hasn't yet been imported. But that button has no effect on
any project that had previously been imported.
TIA,
Christian
Re: How to un-import projects? [message #1514899 is a reply to message #1514801] Wed, 17 December 2014 12:59 Go to previous messageGo to next message
Am 17.12.2014 um 17:19 schrieb Christian W. Damus:
> I can import projects easily using the Oomph Importer wizard. But how can I un-import projects that I no longer need?
That's not possible with Oomph. We generally don't support any "un-perform" of tasks. Given that the task that
originally performed before you removed its Oomph project from your workspace.setup is no longer known to the
SetupTaskPerformer I don't even know how that could be done. It would certainly require fundamental design changes in Oomph.
One solution to your problem is to manually delete the unwanted workspace projects. Another one could be to delete your
workspace folder (assuming that it only contains .metadata that can be recreated by Oomph) and install again. Even
easier would be to just keep the .metadata/.plugins/org.eclipse.oomph.setup/workspace.setup file!
> Hitting the up-arrow button removes a selection from the list at the bottom of the wizard page if it hasn't yet been
> imported. But that button has no effect on any project that had previously been imported.
Yes, that just disassociates the selected Oomph projects from your workspace.setup.
Cheers
/Eike
http://www.esc-net.de
Re: How to un-import projects? [message #1515599 is a reply to message #1514899] Thu, 18 December 2014 02:53 Go to previous messageGo to next message
Assuming Christian isn't asking for an Undo (which seems infeasible) one
can always open the Workspace setup and use the properties view to
remove streams from the Streams property.
> "un-perform" of tasks. Given that the task that originally performed
> longer known to the SetupTaskPerformer I don't even know how that
> in Oomph.
> workspace projects. Another one could be to delete your workspace
> by Oomph) and install again. Even easier would be to just keep the
>> bottom of the wizard page if it hasn't yet been imported. But that
> workspace.setup.
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Re: How to un-import projects? [message #1515964 is a reply to message #1515599] Thu, 18 December 2014 09:40 Go to previous messageGo to next message
Brilliant! Thanks, Ed and Eike. That was exactly what I needed, to
remove the stream from the workspace model. It works like a champ: I
deleted the projects and Oomph didn't restore them when I next started
Eclipse. Makes me wonder, though, why the up-arrow button in the
import wizard doesn't just do this edit to my workspace model for me ...
I've always been hesitant to mess about in those models in the toolbar
menu with the little bust-man, but now I feel like a Power User.
Christian
P.S. Thank you thank you thank you for moving the setup dialog into
the window trim!
> one can always open the Workspace setup and use the properties view to
>> longer known to the SetupTaskPerformer I don't even know how that could
>> workspace.setup.
>> Cheers
>> /Eike
Re: How to un-import projects? [message #1516002 is a reply to message #1515964] Thu, 18 December 2014 10:28 Go to previous message
Christian,
Comments below.
I suppose it could be used to arbitrarily change the workspace's
streams, but it is an "import wizard" so it seems a bit outside of the
scope of its intended purpose.
It's definitely expected that users will edit things like the
Installation or Workspace so include tasks that will affect just that
one installation or just that one workspace...
> Christian
> the window trim!
Yes, that was a challenge because the workbench is slightly buggy with
respect to registering the exact location at which to place such trim
and with respect to toolbar visibility too. But it definitely seems
better that the wizard doesn't do actual significant work until you hit
finish and it's definitely convenient that the long running work can be
managed in the background!
>> to remove streams from the Streams property.
>>> in Oomph.
>>> recreated by Oomph) and install again. Even easier would be to just
>>> file!
>>>> the bottom of the wizard page if it hasn't yet been imported. But
>>>> imported.
>>> workspace.setup.
>>> Cheers
>>> /Eike
Previous Topic:Project import fails on non-existent source folder
Next Topic:[Announce] Oomph is Available in Mars M4
Current Time: Sun Jul 20 08:28:38 EDT 2025
Powered by FUDForum. Page generated in 0.05879 seconds
