Home » Eclipse Projects » Eclipse Platform » DisposeListener not called while widget is disposed...
DisposeListener not called while widget is disposed... [message #151537] Thu, 30 October 2003 11:17 Go to next message
I get the Composite interparent disposed when a refresh of the LabelViewer
instance is done without having the DisposeListener to be called.
How can this situation happen ?
Thank you
PS. When a dispose of the LabelViewer instance is explicitly done I get it
to be called.
public LabelViewer(Composite parent, int style)
interParent = new Composite(parent, SWT.NONE);
interParent.setLayout(new GridLayout(2, false));
interParent.addDisposeListener(new DisposeListener()
public void widgetDisposed(DisposeEvent event)
System.out.println(interParent + " is disposed now");
handleDispose(event);
Re: DisposeListener not called while widget is disposed... [message #151952 is a reply to message #151537] Fri, 31 October 2003 14:32 Go to previous message
Originally posted by: Jacques.Leclercq.pandora.be
My problem is solve, the instances of LabelViewer are registered as
Listener and I forgot to unregister the instance when disposed.
Jacques wrote:
> Thank you
> to be called.
Previous Topic:2.1.2 Release
Next Topic:unedit files in CVS
Current Time: Sat Oct 25 07:22:40 EDT 2025
Powered by FUDForum. Page generated in 0.03119 seconds
