Home » Eclipse Projects » Sirius » How to delete edges ?
How to delete edges ? [message #1508565] Fri, 12 December 2014 09:16 Go to next message
I have a Node object with a [0..*] relationship to other Node Object.
Creating edges works fine. I have a problem in the delete action of this edge using an "Unset".
I tried to do that :
Begin
|_ Change Context var:element
|_ Unset (Feature Name = "etapes"; Element Expression = "[elementView.oclAsType(DEdge).targetNode.oclAsType(DNode).target/]")
index.php/fa/20207/0/
But it doesn't work and i don't know how to solve it.
Anyone can help me or tell me other solution to delete my relationship?
Thanks for the attention.
  • Attachment: unset.PNG
    (Size: 6.37KB, Downloaded 632 times)
[Updated on: Fri, 12 December 2014 09:43] by Moderator
Re: How to delete edges !! [message #1514375 is a reply to message #1508565] Wed, 17 December 2014 03:44 Go to previous messageGo to next message
THe change context should reference the edge source semantic element by
using the same expression you defined within the unset
"[self.sourceNode.oclAsType(DNode).target/]"
The unset "element expression" have to return a collection of elements
to unset from the feature (the edge semantic target in your case)
try with Element Expression =
"[elementView.targetNode.oclAsType(DSemanticDecorator).target/]"
On 12/12/2014 03:16 PM, Ra Cha wrote:
> Begin
> |_ Unset (Feature Name = "etapes"; Element Expression = "[self.sourceNode.oclAsType(DNode).target/]")
Florian - Obeo
Need professional services for Sirius?
Re: How to delete edges !! [message #1514467 is a reply to message #1514375] Wed, 17 December 2014 05:16 Go to previous messageGo to next message
Hi Florian, thanks for your answer.
I followed your instructions but i still have the problem with the following error message :
!MESSAGE Compilation error for expression [elementView.oclAsType(DEdge).targetNode.oclAsType(DSemanticDecorator).target/] : Unrecognized variable: (DSemanticDecorator)
Begin
|_ Change Context [elementView.oclAsType(DEdge).sourceNode.oclAsType(DNode).target/]
|_ Unset (Feature Name = "etapes"; Element Expression = "[elementView.oclAsType(DEdge).targetNode.oclAsType(DSemanticDecorator).target/]")
Thank you for your help.
Re: How to delete edges !! [message #1514508 is a reply to message #1514467] Wed, 17 December 2014 05:58 Go to previous messageGo to next message
Replace DSemanticDecorator by viewpoint::DSemanticDecorator; (the
acceleo parser needs of the package in this case)
> following error message : !MESSAGE Compilation error for expression
> Begin
> |_ Change Context
Florian - Obeo
Re: How to delete edges !! [message #1514807 is a reply to message #1514508] Wed, 17 December 2014 11:23 Go to previous messageGo to next message
Thank you for the reply. But, i have the same error...
Re: How to delete edges !! [message #1515912 is a reply to message #1514807] Thu, 18 December 2014 08:45 Go to previous message
That's strange. And if you replace DSemanticDecorator by a more concrete
type ? (DNode, DNodeList, following what is the real element behind)
Florian - Obeo
Previous Topic:Context of content in Sirius
Next Topic:Reusing Edges with new Nodes
Current Time: Sun Jul 27 10:04:21 EDT 2025
Powered by FUDForum. Page generated in 0.06474 seconds
