Using Jubula with multiple test writers [message #890328] |
Thu, 21 June 2012 23:10  |
What's the best way to handle multiple test writers concurrently working on the same test project in Jubula?
For example, should all our Jubula instances be pointing to a central db that contains the project. If multiple users are working on this project and interacting with this central database at the same time are there any race-condition issues?
Alternatively, should we be working on separate db instances, exporting our projects, and then manually merging these project files? This seems really messy. From what I can see you can only export the whole project. It would be great to only export a test suite, and also be able to export without including test summary data.
What's would you suggest?
Cheers
FUDForum. Page generated in 0.03785 seconds
