Home » Eclipse Projects » GEF » 2 figures on 2 different layers
2 figures on 2 different layers [message #150905] Wed, 15 September 2004 10:09 Go to next message
I would like to draw 2 figures on 2 different layers, someone can
explain-me how I can do that ?
Sabri.
Re: 2 figures on 2 different layers [message #151082 is a reply to message #150905] Wed, 15 September 2004 11:09 Go to previous messageGo to next message
From purely a Draw2d perspective? You create a LayeredPane, add two layers
to it, and then add a figure to each of those layers.
If you're using GEF, you can access a layer from your EditPart's
getLayer(id) method.
"Skhiri Gabouje Sabri" <sskhirid@ulb.ac.be> wrote in message
news:ci9ie9$to4$1@eclipse.org...
> Sabri.
Re: 2 figures on 2 different layers [message #151194 is a reply to message #151082] Thu, 16 September 2004 05:13 Go to previous messageGo to next message
Thanks for your response Patrik,
Ok, but I tried that, but nothing appears. My main figure is a
figureCanvas, can I directly add a layeredPane to the figureCanvas ?
Sabri.
> > Hi,
> > Thanks,
> > Sabri.
Re: 2 figures on 2 different layers [message #151239 is a reply to message #151194] Thu, 16 September 2004 11:01 Go to previous messageGo to next message
Please look at NonResizableEditPolicy and how it adds handle figures to the
handle layer.
"Skhiri dit Gabouje Sabri" <sskhirid@ulb.ac.be> wrote in message
news:ciblgh$5v2$1@eclipse.org...
> Sabri.
layers
> > > Hi,
> > > Thanks,
> > > Sabri.
Re: 2 figures on 2 different layers [message #151294 is a reply to message #151239] Fri, 17 September 2004 04:14 Go to previous messageGo to next message
Thanks Randy, sorry for my stupid questions but I looked to this class
and I understand how the layer mechanisms work. Bu My situation is quiet
different. I use a simple draw2DView, I have a FigureCanvas linked to a
LightweightSystem, and my main Figure is a Simple Figure. Here is a piece
of code of the createPartControl() of my ViewPart:
LayeredPane mainPane = new FreeformLayeredPane();
Layer figureLayer = new FreeformLayer();
mainPane.add(figureLayer, LayerConstants.PRIMARY_LAYER);
mainPane.setOpaque(false);
figureLayer.setOpaque(false);
figure = (IFIgure) getSimpleFigure();
figure.setOpaque(false);
system = new LightweightSystem(principalCanvas);
principalCanvas = new FigureCanvas(parent, system);
figureLayer.add(figure);
principalCanvas.getViewport().setContents(mainPane);
Nothing appears in the view, while if I add directly the figure
principalCanvas.getViewport().setContents(figure) , without using
LayeredPane it works well, my figure appears.
Then, I'm doing something wrong ?
Sabri.
> handle layer.
> > Sabri.
> layers
> > > > Hi,
> > > > Thanks,
> > > > Sabri.
Re: 2 figures on 2 different layers [message #151447 is a reply to message #151294] Mon, 20 September 2004 10:34 Go to previous messageGo to next message
Are you using a FreeformViewport??
"Skhiri dit Gabouje Sabr" <sskhirid@ulb.ac.be> wrote in message
news:cie6cc$6i7$1@eclipse.org...
> Sabri.
the
> > handle layer.
> > > Sabri.
> > layers
> > > > > Hi,
> > > > > Thanks,
> > > > > Sabri.
Re: 2 figures on 2 different layers [message #151791 is a reply to message #151447] Thu, 23 September 2004 02:56 Go to previous message
Even if I add this two lines:
FreeformViewport viewPort = new FreeformViewport();
principalCanvas.setViewport(viewPort);
It doesn't work.
Sabri.
> > Thanks,
> > Sabri.
> the
> > > handle layer.
> > > > Sabri.
> > > layers
> > > > > > Hi,
> > > > > > Thanks,
> > > > > > Sabri.
Previous Topic:Repopulate palette -- Null pointer in PaletteViewer
Next Topic:MS Project style interface
Current Time: Sun Jul 20 23:42:52 EDT 2025
Powered by FUDForum. Page generated in 0.24777 seconds
