how to format date values in charts [message #151121] |
Wed, 05 April 2006 10:35  |
Originally posted by: stefano.comarin.primeur.com
I would like to format the date value on the X axis of charts according
to the user locale. Is it possible to do this at runtime with Javascript?
Stefano
Re: how to format date values in charts [message #151514 is a reply to message #151417] |
Thu, 06 April 2006 11:24   |
I use the Format Specified Editor in the Chart Editor. I set the X axis
type to DateTime, format = Standard, Type = Short, Details = DateTime.
Stefano
David Michonneau wrote:
> Did you format the date with the format UI?
> David
> "Stefano Comarin" <stefano.comarin@primeur.com> wrote in message
> news:e130lo$2j5$1@utils.eclipse.org...
>>The axis is set as date type but it does not adjust on the locale.
>>I tried to change the locale but the date format in charts is always the
>>same (US English). Is this maybe a bug?
>>Thanks,
>>Stefano
>>>Doesn't the format specifier allow you to do that already? If you click
>>>on format button for the x axis labels, you can specify a date format
>>>(given the axis is set as date type). I believe it should adjust at
>>>runtime depending on the locale.
>>>Thanks,
>>>David
>>>news:e10kiq$fab$1@utils.eclipse.org...
>>>>Hi,
>>>>Thanks,
>>>>Stefano
Re: how to format date values in charts [message #151822 is a reply to message #151514] |
Fri, 07 April 2006 04:32  |
Please file a bugzilla entry in that case.
David
news:e13bql$kqe$1@utils.eclipse.org...
> Stefano
>> Thanks,
>> David
>>>Thanks,
>>>Stefano
>>>>Thanks,
>>>>David
>>>>>Hi,
>>>>>Javascript?
>>>>>Thanks,
>>>>>Stefano
FUDForum. Page generated in 0.04495 seconds
