Home » Eclipse Projects » GEF » PolygonFigure
PolygonFigure [message #150863] Tue, 14 September 2004 18:05 Go to next message
Originally posted by: seasnake.gmx.li
I'm using a Polygon to draw a rhombus but i get a strange behavior:
When the rightmost vertex and the bottom vertex of rhombus match the bound
of the constrain used to place the Figure in editor then moving the edit
part with mouse lets the selection handles stay where the edit part was
and the Figure itself is moved. I can interrupt moving the Figure around
and start again, but this has no effect on selection handles.
Drawing a rhombus smaller or greater than the constrain provides the
desired behavior.
Is there a solution to avoid this problem?
Best regards
Ilja
Re: PolygonFigure [message #150877 is a reply to message #150863] Tue, 14 September 2004 18:47 Go to previous messageGo to next message
I don't understand what you're saying. Are you saying that you're
experiencing this problem in the case where the rhombus is a square? Please
clarify what the problem is.
"Ilja" <seasnake@gmx.li> wrote in message news:ci7pus$6to$1@eclipse.org...
> desired behavior.
> Best regards
> Ilja
Re: PolygonFigure [message #151101 is a reply to message #150863] Wed, 15 September 2004 12:41 Go to previous messageGo to next message
There is a Figure class called Polygon. It is not designed to be dragged or
placed by its bounds. Have you created your own class called
PolygonFigure??
> desired behavior.
> Best regards
> Ilja
Re: PolygonFigure [message #151133 is a reply to message #151101] Wed, 15 September 2004 15:39 Go to previous messageGo to next message
I didn't create a PolygonFigure. Here the refreshVisuals code:
protected void refreshVisuals() {
Association assoc = (Association) getModel();
Polygon outline = (Polygon) getFigure();
Point leftTopCornerLoc = assoc.getLocation();
Dimension size = assoc.getSizes();
PointList vertices = new PointList(4);
Point rhombusVertex = new Point();
// vertex in the top middle of the rect
rhombusVertex.x = leftTopCornerLoc.x + size.width / 2;
rhombusVertex.y = leftTopCornerLoc.y;
vertices.addPoint(rhombusVertex);
// vertex in the right middle of the rect
rhombusVertex.x = leftTopCornerLoc.x + size.width;
rhombusVertex.y = leftTopCornerLoc.y + size.height / 2;
// vertex in the bottom middle of the rect
rhombusVertex.y = leftTopCornerLoc.y + size.height;
// vertex in the left middle of the rect
rhombusVertex.x = leftTopCornerLoc.x;
outline.setPoints(vertices);
Rectangle r = new Rectangle(leftTopCornerLoc, size);
((GraphicalEditPart) getParent()).setLayoutConstraint(this, outline,
r);
> PolygonFigure??
> > desired behavior.
> > Best regards
> > Ilja
Re: PolygonFigure [message #151141 is a reply to message #150877] Wed, 15 September 2004 15:40 Go to previous messageGo to next message
here is my code:
r);
> > desired behavior.
> > Best regards
> > Ilja
Re: PolygonFigure [message #151149 is a reply to message #151133] Wed, 15 September 2004 17:34 Go to previous messageGo to next message
XYLayout will be calling setBounds() which is not supported by Polygon.
But, besides that, there is a bug in your code. You cannot paint on the
right and bottom sides of the bounding box, so you should either make the
box bigger, or bring in the points by 1 pixel.
"Ilja" <seasnake@gmx.li> wrote in message news:cia5pv$2ng$1@eclipse.org...
> r);
dragged or
> > PolygonFigure??
bound
edit
was
around
> > > desired behavior.
> > > Best regards
> > > Ilja
Re: PolygonFigure [message #151156 is a reply to message #151149] Wed, 15 September 2004 17:59 Go to previous message
Hi Randy, thank you. Well there is no bug the "bug" will occur when I
whould subtract 1 from the width and the height. And this lead to behavior
described below.
I will follow your advise and just make my rhombus 1 pixel smaller than my
bounding rect.
Thank you for your help
Best regards
Ilja
Previous Topic:Link Connection not deleted when connected to a child of a deleted parent.
Next Topic:Hatching
Current Time: Thu Sep 18 04:54:49 EDT 2025
Powered by FUDForum. Page generated in 0.05827 seconds
