Home » Archived » BIRT » Order form in the "Installing BIRT Viewer in Tomcat" tutorial?
Order form in the "Installing BIRT Viewer in Tomcat" tutorial? [message #147731] Fri, 24 March 2006 03:36 Go to next message
Originally posted by: jwbats.gmail.com
Dear Readers,
I have worked my way through this tutorial:
http://www.eclipse.org/birt/phoenix/deploy/viewerSetup.php
And somewhere in the tutorial, it says:
"If you've installed everything in its default location, then click on the
following link. If you've changed anything, then copy the following URL
into your browser and make the needed changes.
http://localhost:8080/birt-viewer/run?__report=Report\SalesI nvoice.rptdesign
The report should run and appear in your browser, along with a parameter
form in which you can enter a different value for the "Order Number "
parameter for this report."
My problem is, I don't get to see an order form where I can input an order
number myself. It's just a static page that shows information for order
number 363. There's nothing to edit there.
What am I doing wrong?
Re: Order form in the "Installing BIRT Viewer in Tomcat" tutorial? [message #150089 is a reply to message #147731] Sat, 01 April 2006 10:00 Go to previous messageGo to next message
Originally posted by: David.Peterson.mtvnmix.com
I don't think you're doing anything wrong here as I don't see it either. I
also installed my own forms into tomcat just to make sure it wasn't
something wrong with the tutorial and they don't work either. I'm going to
create a Birt bug report for this and I'll re-post it here so that we can
track its progress.
Re: Order form in the "Installing BIRT Viewer in Tomcat" tutorial? [message #150106 is a reply to message #147731] Sat, 01 April 2006 10:13 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=134365
Re: Order form in the "Installing BIRT Viewer in Tomcat" tutorial? [message #150495 is a reply to message #150089] Mon, 03 April 2006 19:00 Go to previous messageGo to next message
The viewer page needs to be updated.
The run command no longer shows the parameter page.
use the /frameset command.
Jason
"David Peterson" <David.Peterson@mtvnmix.com> wrote in message
news:e0m4it$vvd$1@utils.eclipse.org...
>track its progress.
Re: Order form in the "Installing BIRT Viewer in Tomcat" tutorial? [message #151113 is a reply to message #147731] Wed, 05 April 2006 08:51 Go to previous messageGo to next message
1. The instructions are confused. If the servlet path is "run", the
parameter form will not appear.
2. I created a bug 134938 to let documention group to revise the
instructions.
3. If the serlvet path is "frameset", the 3 icons will be shown;
however, they do not appear if the path is "run". "run" just executes
the report and show the result and layout to the user.
Re: Order form in the "Installing BIRT Viewer in Tomcat" tutorial? [message #152109 is a reply to message #147731] Sat, 08 April 2006 12:01 Go to previous message
Instructions were wrong, but are now updated. It's improved, but still not
right. I'm getting 3 javascript errors. Awaiting futher advice from
accuate.
Previous Topic:Where do jars with db drivers need to go for BIRT viewer in Tomcat
Next Topic:birtParameterDialog
Current Time: Wed Nov 05 19:57:07 EST 2025
Powered by FUDForum. Page generated in 0.06021 seconds
