running make in directory outside the project [message #151093] |
Fri, 12 August 2005 11:45  |
Originally posted by: michal.schulz.gmx.de
Hello.
I'm new and quite happy user of eclipse and CDT. I have only one problem.
The project I work on is quite big (180MB approximatelly) with tons of
files. If I would turn indexing on, eclipse would need ages to go through
all files and index them. Also, updating project after build is awfully
slow.
Due to nature of this project, I can work on one of modules only, and thus
keep the ability of indexing and fast responsivity of eclipse. However, I
have to tell eclipse that the project directory resides somewhere within my
big project.
Can I force eclipse to start makefile in specified directory, whereas the
directory is outside the project managed by eclipse?
Michal.
Re: running make in directory outside the project [message #151127 is a reply to message #151093] |
Sun, 14 August 2005 15:29   |
Michal Schulz wrote:
> Hello.
> slow.
> big project.
> Regards,
> Michal.
That's what I'm doing in my environment. If you are not using "managed
make" (and since working with big "legacy" project I assume you don't)
you can specify any build command you like.
I'm using something like this as a build command:
make -C /my_home_dir/root_of_my_project -f our_very_fat_makefile
Than in fields that specify targets for building, rebuilding and
cleaning I specify targets from the fat_makefile related to my module.
CK
Re: running make in directory outside the project [message #151339 is a reply to message #151143] |
Wed, 17 August 2005 05:08  |
> Thanks!
> I've never thought that the solution might be so simple :)
> regards,
> M.
You are welcome.
One more tip: when specifying path to the maim makefile you could use
${project_loc} variable and path relative to your .project. Saves some
time when working on multiple source trees.
CK
FUDForum. Page generated in 0.04253 seconds
