Home » Modeling » Papyrus » papyrus apply a stereotype twice on an elmenet(can not specify two kinds of hosts that performing a job concurrently)
papyrus apply a stereotype twice on an elmenet [message #1508301] Fri, 12 December 2014 04:35 Go to next message
An action may need multiple hosts (resources) to be executed. In Papyrus, I can specify a stereotype of "PaStep" with two host on an action node. Nor can I specify two stereotypes of "PaStep" on the same node, and each one has a different host.
The problem above is that one kind of stereotype can not specified on one action node twice.
What can I do? There is a property in "PaStep" -- "usedResources", but I prefer not to use it. I think it natural that there exist several hosts to performing the job.
Please, help Razz
Re: papyrus apply a stereotype twice on an elmenet [message #1508480 is a reply to message #1508301] Fri, 12 December 2014 07:57 Go to previous messageGo to next message
In UML, a stereotype is conceptually an "extension" of a metaclass that
adds attributes to that metaclass. Repeating a stereotype would
logically repeat attributes in the extended metaclass, which does not
make sense. The UML does not permit repeated application of a
stereotype.
You would be better served by explicitly modeling the multiplicity of
nodes in your stereotype by either
- representing the node by a Class contained by the stereotype in a
property that has
multiplicity
- representing the node by a stereotype on some other kind of UML element and
defining an association between the two stereotypes
HTH,
Christian
> Please, help :p
Re: papyrus apply a stereotype twice on an elmenet [message #1509704 is a reply to message #1508480] Sat, 13 December 2014 07:52 Go to previous messageGo to next message
Thanks for your detailed reply! Smile
But I do not quite understand the suggestion you offered. Should I represent an action with two hosts by two separate actions, and each of them has a host?
This may be a solution though not quite elegant.
And the "node" in your solutions refers to the action or the resource node? Could you please give some more explanation.
Re: papyrus apply a stereotype twice on an elmenet [message #1509706 is a reply to message #1508480] Sat, 13 December 2014 07:54 Go to previous messageGo to next message
Christian W. Damus wrote on Fri, 12 December 2014 07:57
stereotype.
property that has
multiplicity
HTH,
Christian
> Please, help Razz
Re: papyrus apply a stereotype twice on an elmenet [message #1509723 is a reply to message #1508480] Sat, 13 December 2014 08:12 Go to previous messageGo to next message
While repetition of exactly the same stereotype my be prohibited,
multiple application of the stereotype is not prohibited. You may chose
to introduce Source/Target derived stereotypes for your two hosts.
Ed Willink
On 12/12/2014 12:57, Christian W. Damus wrote:
> make sense. The UML does not permit repeated application of a stereotype.
> property that has
> multiplicity
> element and
> HTH,
> Christian
>> Please, help :p
Re: papyrus apply a stereotype twice on an elmenet [message #1509769 is a reply to message #1509723] Sat, 13 December 2014 09:06 Go to previous messageGo to next message
This is ture that I have tried to apply the stereotypes of "PaStep" and "GaStep"(also, "AcqStep" and "RelStep") on one action. But it seems not elegant.
What is "Source/Target derived stereotypes"? Could you please explain it more specifically or give some references.
Xiang Hu
Ed Willink wrote on Sat, 13 December 2014 08:12
Ed Willink
> property that has
> multiplicity
> element and
> HTH,
> Christian
>> Please, help Razz
Re: papyrus apply a stereotype twice on an elmenet [message #1509824 is a reply to message #1509769] Sat, 13 December 2014 10:12 Go to previous messageGo to next message
A derived stereotype for your 'source' role possibly named "Source". etc...
Ed Willink
On 13/12/2014 14:06, hu xiang wrote:
> elegant.
> Regards,
> Xiang Hu
>> Hi
>> chose to introduce Source/Target derived stereotypes for your two hosts.
>> Regards
>> Ed Willink
>> > Hi,
>> stereotype.
>> > property that has
>> > multiplicity
>> > element and
>> > HTH,
>> > Christian
>> >> Please, help :p
Re: papyrus apply a stereotype twice on an elmenet [message #1510388 is a reply to message #1509824] Sat, 13 December 2014 21:46 Go to previous messageGo to next message
Thanks, but I still don't know how to specify them in Papyrus. In a activity diagram, an action with multiple "host", how to specify multiple stereotypes of "PaStep" on this action. In the view of "Model Explorer" or "Properties", I can't find any way to operate on stereotypes. The only thing I can do is to add/remove/edit a stereotype, how to specify derived stereotypes as you said.
Smile
Re: papyrus apply a stereotype twice on an elmenet [message #1510738 is a reply to message #1510388] Sun, 14 December 2014 04:55 Go to previous messageGo to next message
You create another Stereotype that is derived from/inherits/specializes
the one you already have. Then you can add it.
Ed Willink
> Regards,
Re: papyrus apply a stereotype twice on an elmenet [message #1510864 is a reply to message #1510738] Sun, 14 December 2014 07:25 Go to previous message
Thanks again, your answers are of great help to me. Very Happy
Previous Topic:Navigating association class(stereotype) in an OCL constraint
Next Topic:Papyrus 1.0 SR1a
Current Time: Sun Jul 27 13:47:39 EDT 2025
Powered by FUDForum. Page generated in 0.05036 seconds
