Home » Language IDEs » Java Development Tools (JDT) » how to change font
how to change font [message #15073] Tue, 06 May 2003 11:39 Go to next message
Originally posted by: fxn.isoco.com
Is there a way to change the font used in non-editor panels such as the
Navigator and friends? The default font is too big for this 800x600. This
is under Linux, if that matters.
-- fxn
Re: how to change font [message #15082 is a reply to message #15073] Tue, 06 May 2003 14:34 Go to previous messageGo to next message
<posted & mailed>
> -- fxn
If You have linux gtk set .gtkrc or .gtkrc-2.0 (for gtk >= 2.0) in home dir,
btw.
include "/usr/share/themes/gnuAquaSE/gtk-2.0/gtkrc"
# -- THEME AUTO-WRITTEN DO NOT EDIT
style "eclipse" {
font_name = "Helvetica 12"
# you can change colors
# bg[NORMAL] = "#xxxxxx"
# bg[ACTIVE] = "#xxxxxx"
# bg[INSENSITIVE] = "#xxxxxx"
# bg[PRELIGHT] = "#xxxxxx"
# fg[NORMAL] = "#000000"
# fg[ACTIVE] = "#000000"
# fg[INSENSITIVE] = "#xxxxxx"
# fg[PRELIGHT] = "#ffffff"
class "GtkWidget" style "eclipse"
# Setup use of Anti-Aliasing of fonts. 1 is on and 0 is off. On by
default.
GDK_USE_XFT=1
I You use motif change to gtk
regards
Haris Peco
Re: how to change font [message #15086 is a reply to message #15073] Tue, 06 May 2003 14:36 Go to previous messageGo to next message
<posted & mailed>
> -- fxn
If you use gtk set .gtkrc or .gtkrc-2.0 in home dir. like :
style "eclipse" {
default.
GDK_USE_XFT=1
regards
Haris Peco
Re: how to change font [message #15931 is a reply to message #15073] Tue, 06 May 2003 18:43 Go to previous messageGo to next message
For Motif:
http://dev.eclipse.org/viewcvs/index.cgi/~checkout~/platform -swt-home/faq.html#motiffontsandcolors
For GTK:
http://dev.eclipse.org/viewcvs/index.cgi/~checkout~/platform -swt-home/faq.html#gtkfontsandcolors
Stanimir
Re: how to change font [message #17075 is a reply to message #15931] Thu, 08 May 2003 05:06 Go to previous messageGo to next message
> For GTK:
No luck, I've done a lot of trials and the font in the Navigator, Outline,
CVS Repositories, etc. is always the same. I don't know what could I do
next.
This is running under Debian unstable with KDE 3.1.1. KDE uses anti-aliased
fonts. I have played both with .gtkrc and .gtkrc-2.0. Some applications, as
Grip, change the fonts according to .gtkrc, but they are not anti-aliased.
On the other hand, fonts in Eclipse are anti-aliased.
Any ideas?
-- fxn
Re: how to change font [message #20205 is a reply to message #17075] Mon, 12 May 2003 15:19 Go to previous message
>> For GTK:
> next.
Could you post your .gtkrc file declarations? May be someone could
help better that way.
> Any ideas?
When I've tried Eclipse under Linux it used .gtkrc-2.0 file so I
believe your customizations should go there. Actually I haven't used
the example given in the above URL but copied .gtkrc-kde file which
is generated by the KDE Control Center when choosing to change the
colors for non-KDE applications too. Then I added a font declaration
and everything gone fine. According to this document:
http://developer.gnome.org/doc/API/gtk/gtk-resource-files.ht ml#AEN4785
the font declaration should be:
style * {
font = "Sans 12"
and in the example there is given:
font_name = "Sans 12"
which is probably errorneous. As for the font anti-aliasing: may be
some older GTK applications use older libraries which doesn't
support font anti-aliasing.
Stanimir
Previous Topic:Search UI problems
Next Topic:Package Explorer's content provider extension
Current Time: Mon Nov 03 07:38:43 EST 2025
Powered by FUDForum. Page generated in 0.78493 seconds
