Home » Modeling » QVT-OML » handling of abstract types
handling of abstract types [message #1508490] Fri, 12 December 2014 08:06 Go to next message
Hello, I'm working with an XSD-derived model, where I have the following complexType:
<xs:complexType name="IntervalType">
<xs:sequence>
<xs:element ref="xcal:dtstart" minOccurs="0"/>
<xs:element ref="xcal:duration" minOccurs="0"/>
<xs:element ref="xcal:uid" minOccurs="0"/>
<xs:element ref="strm:streamPayloadBase" maxOccurs="unbounded"/>
</xs:sequence>
</xs:complexType>
I'm trying, in QVTO, to assign to "streamPayloadBase", which is abstract:
<xs:complexType name="StreamPayloadBaseType" abstract="true">
<xs:annotation>
<xs:documentation>Abstract class to convey a payload for a stream. When a Stream is transformed to or from a WS-Calendar Interval, the contents of the Stream Payload defined element are transformed into the contents of a WS-Calendar artifactBase.</xs:documentation>
</xs:annotation>
</xs:complexType>
I'm using this syntax:
object IntervalType{
streamPayloadBase += OrderedSet {
object SignalPayloadType {}
where "SignalPayloadType" is a concrete child of "StreamPayloadBaseType". However, I cannot do this, since I get the error:
"Property 'streamPayloadBase' is read-only"
How can I solve this problem?
Thanks a lot,
Daniele Pala
Re: handling of abstract types [message #1508548 is a reply to message #1508490] Fri, 12 December 2014 09:04 Go to previous messageGo to next message
It may be appropriate to start with XSD for external compatibility, but
as soon as you convert to Ecore you can join the grown ups and use models.
It would appear that your Ecore model has a readonly attribute
prohibiting the change. You may investigate whether this is an XSD to
Ecore conversion anomally, or just correct it. You should then be good
to go.
Without a *.ecore to look at it's hard to comment further.
Ed Willink
> complexType:
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> <xs:annotation>
> </xs:annotation>
> </xs:complexType>
> Thanks a lot,
> Daniele Pala
Re: handling of abstract types [message #1514817 is a reply to message #1508548] Wed, 17 December 2014 11:33 Go to previous messageGo to next message
Thanks for your reply. Actually I found that, along with 'streamPayloadBase' which is read-only, there is a property 'streamPayloadBaseGroup', which is a sequence of 'EFeatureMapEntry'...but probably I must use a backbox operation to deal with this EFeatureMap stuff, right?
Daniele Pala
Re: handling of abstract types [message #1514829 is a reply to message #1508548] Wed, 17 December 2014 11:40 Go to previous message
The fact that 'streamPayloadBase' is read-only is correct however, since only its 'concrete childs' must be settable...like SignalPayloadType...probably this can only be done via EFeatureMaps Sad
Daniele
Previous Topic:Including UML primitive types in result of transformation
Next Topic:Compilation errors found when running a transformation inside the jboss container
Current Time: Sat Jul 26 20:01:26 EDT 2025
Powered by FUDForum. Page generated in 0.04356 seconds
