Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMFCompare, Edapt] Install different versions
[EMFCompare, Edapt] Install different versions [message #1507399] Thu, 11 December 2014 10:46 Go to next message
Hi there,
I try to install EMFCompare v3 and Edapt 1. I get the error below. I
assume that Edapt uses an earlier version of EMFCompare.
It seems that differen versions of EMFCompare core cannot be installed
at the same time. Why is that a problem? I thought this is all the
purpose of OSGi and Eclipse using plugins which can be made in different
versions in the same installation. Any solution?
Hauke
Cannot complete the install because of a conflicting dependency.
Software being installed: EMF Compare SDK 1.3.2.v20120918-1125
(org.eclipse.emf.compare.sdk.feature.group 1.3.2.v20120918-1125)
Software currently installed: Edapt Recorder Feature
1.0.0.201411071217 (org.eclipse.emf.edapt.recorder.feature.feature.group
1.0.0.201411071217)
Only one of the following can be installed at once:
EMF Compare core 1.2.1.v20110913-0926 (org.eclipse.emf.compare
1.2.1.v20110913-0926)
EMF Compare core 1.1.0.v201006150400 (org.eclipse.emf.compare
1.1.0.v201006150400)
EMF Compare core 1.3.2.v20120918-1125 (org.eclipse.emf.compare
EMF Compare core 1.0.1.v200909161031 (org.eclipse.emf.compare
1.0.1.v200909161031)
EMF Compare core 1.2.2.v20120214-0915 (org.eclipse.emf.compare
1.2.2.v20120214-0915)
EMF Compare core 1.2.0.v20110607-2028 (org.eclipse.emf.compare
1.2.0.v20110607-2028)
EMF Compare core 1.3.1.v20120605-0748 (org.eclipse.emf.compare
1.3.1.v20120605-0748)
EMF Compare Core 2.0.0.201209121410 (org.eclipse.emf.compare
2.0.0.201209121410)
EMF Compare core 1.0.0.v200906220949 (org.eclipse.emf.compare
1.0.0.v200906220949)
EMF Compare core 1.1.1.v201009150438 (org.eclipse.emf.compare
1.1.1.v201009150438)
EMF Compare Core 3.0.1.201309031318 (org.eclipse.emf.compare
3.0.1.201309031318)
Cannot satisfy dependency:
(org.eclipse.emf.compare.feature.group 1.3.2.v20120918-1125)
To: org.eclipse.emf.compare [1.3.2.v20120918-1125]
To: org.eclipse.emf.compare.feature.group [1.3.2.v20120918-1125]
From: Edapt History Edit Support 1.0.0.201411071217
(org.eclipse.emf.edapt.history.edit 1.0.0.201411071217)
To: bundle org.eclipse.emf.compare [3.0.0,4.0.0)
(org.eclipse.emf.edapt.recorder.feature.feature.group 1.0.0.201411071217)
To: org.eclipse.emf.edapt.history.edit [1.0.0.201411071217]
Re: [EMFCompare, Edapt] Install different versions [message #1512260 is a reply to message #1507399] Mon, 15 December 2014 10:55 Go to previous messageGo to next message
Hi Hauke,
It seems that you are trying to install EMFCompare 1.3 instead of 3.
Edapt and EMFCompare 3 can be installed in the same IDE.
Best regards
Johannes
Hauke Fuhrmann wrote on Thu, 11 December 2014 15:46
Hi there,
Hauke
1.0.0.201411071217)
2.0.0.201209121410)
3.0.1.201309031318)
Re: [EMFCompare, Edapt] Install different versions [message #1513099 is a reply to message #1512260] Tue, 16 December 2014 03:11 Go to previous messageGo to next message
Hi Johannes,
no, I'm installing EMF Compare in Eclipse Luna via the Eclipse
Marketplace, which states that it is EMF Compare 3, which I'm installing.
The wizard shows that it installs from
http://download.eclipse.org/modeling/emf/compare/updates/releases the
feature "EMF Compare SDK" from the category "EMF compare: model
comparison and merge 3.0". If this feature contains older version
numbers, there is something wrong with the marketplace/updatesite.
I tried to install manually via update site
http://download.eclipse.org/modeling/emf/compare/updates/releases/latest
From the update site it works fine. So there must be some issue with
the marketplace?
Hauke
Am 15.12.2014 16:55, schrieb Johannes Faltermeier:
> Hi Hauke,
> Best regards
> Johannes
>> Hi there,
>> different versions in the same installation. Any solution?
>> Cheers,
>> Hauke
>> 1.0.0.201411071217
>> 2.0.0.201209121410)
>> 3.0.1.201309031318)
>> From: EMF Compare 1.3.2.v20120918-1125
>> From: EMF Compare SDK 1.3.2.v20120918-1125
>> From: Edapt Recorder Feature 1.0.0.201411071217
Re: [EMFCompare, Edapt] Install different versions [message #1514709 is a reply to message #1507399] Wed, 17 December 2014 09:31 Go to previous message
Hi Hauke,
I'm the project lead of EMF Compare. Sorry about the mistake. The marketplace were referencing the wrong feature id (one that was existing only in 1.3 and before) so the marketpalce was always trying to install version 1.3.
I fixed the issue and you should now be able to install it properly.
Sorry for the disturbance and thank you for having raised the issue.
Previous Topic:[Edapt] support of xcore ?
Next Topic:[EMF Forms] JavaFX sample application ?
Current Time: Thu Jul 24 22:49:18 EDT 2025
Powered by FUDForum. Page generated in 0.30174 seconds
