Home » Language IDEs » ServerTools (WTP) » Dependent web modules don't deploy
Dependent web modules don't deploy [message #150723] Mon, 05 December 2005 00:55 Go to next message
Originally posted by: compsci101.hotmail.com
I'm wondering if anyone else is experiencing this same problem under
WTP1.0 RC1:
I have a web project that depends on another utility web project -- on
project deployment, however, only the main project gets WAR'd up. The
utility project does not.
The utility project DOES contribute to the build, however -- Java classes
depending on classes in the utility project compile properly.
Does anybody know how I can get the utility project to deploy as well?
C
Re: Dependent web modules don't deploy [message #150747 is a reply to message #150723] Mon, 05 December 2005 06:18 Go to previous messageGo to next message
> WTP1.0 RC1:
> classes depending on classes in the utility project compile properly.
Deploy ? as in get copied into WEB-INF/lib inside the super-project's WAR ?
Sounds like you have the required projects setup correctly in the build
path of the super-project, good for the build.
But you dont have J2EE Module Dependancies configured in the
super-project, not good to test/export.
Right click on the super-project -> Properties find J2EE Module
Dependancies and you should see listed your sub-project that you can
tick. If you dont check the project types of both projects (Properties
-> Server).
Darryl
Re: Dependent web modules don't deploy [message #151475 is a reply to message #150747] Mon, 12 December 2005 12:06 Go to previous message
>> WTP1.0 RC1:
> WAR ?
> -> Server).
It's not working for me, I marked a project as a "J2EE Module
Dependency" for another project but it's still not deployed. How can I
debug what's happening?
Daniel Serodio
Previous Topic:dependency deplyoment tomcat
Next Topic:Publishing problems with RC1 & RC2
Current Time: Sat Jul 19 01:08:06 EDT 2025
Powered by FUDForum. Page generated in 0.05782 seconds
