Home » Language IDEs » C / C++ IDE (CDT) » C Socket Programming
C Socket Programming [message #1507192] Thu, 11 December 2014 06:54
Hi everyone,
I'm using C Socket for a simple communication between an Ethernet Connection.
The two end points are: Notebook (it's the machine where the Server is running) and an FPGA (where the client should run), the protocol in use must be UDP.
I read on internet that it's possible to solve some problems of UDP by using the UDP with connection, so, that's what I'm trying to develop.
Below there is the code of server and client.
SERVER:
#define SERVERADDRESS "10.3.0.72"
#define MAXBUF 128
int main(int argc, char * argv[])
	int server_socket, connect_socket, retcode, nw;
	socklen_t client_addr_len;
	struct sockaddr_in server_addr, client_addr;
	char buffer[MAXBUF];
	char * client_address; // lo useremo come indirizzo del client in formato stringa
	// apertura socket del server
	if (((server_socket = socket(PF_INET,SOCK_DGRAM,0))) == -1)
		perror("Error in server socket()");
		exit(-1);
	// preparazione dell'indirizzo locale del server
	server_addr.sin_family = AF_INET;
	server_addr.sin_port = htons(0);
	server_addr.sin_addr.s_addr = inet_addr(SERVERADDRESS);
	memset(server_addr.sin_zero,'/0',sizeof(server_addr.sin_zero));
	// bind del socket
	if ((retcode = bind (server_socket, (struct sockaddr*)  &server_addr, sizeof(server_addr))) == -1)
		perror("Error in server socket bind()");
		exit(-1);
	// listen del socket
	if ((retcode = listen(server_socket, 10)) == -1)
		perror("Error in server socket listen()");
		exit(-1);
	printf("Server ready (CTRL-C quits)\n");
	client_addr_len = sizeof(client_addr);
	// cicla in attesa di connessione
	while (1)
		// accetta le connessioni
		if ((connect_socket = accept(server_socket, (struct sockaddr *)&client_addr, &client_addr_len)) == -1)
			perror("Error in accept()");
			exit(-1);
		// memorizzo l'indirizzo del client in formato stringa
		client_address = inet_ntoa(client_addr.sin_addr);
		printf("\nClient @ %s connects on socket %d\n", client_address, connect_socket);
		// riceve i messaggi e li stampa in output
		while ((retcode = recv(connect_socket,buffer,MAXBUF,0)) > 0)
			buffer[retcode] = '\0'; // buffer dev'essere una stringa
			printf(">> %s: %s\n", client_address, buffer);
		// chiudo la socket
		close(connect_socket);
CLIENT:
int main(int argc, char *argv[])
	int client_socket;
	struct sockaddr_in server_addr;
	char *msg = 'CIAO SONO IL CLIENT';
	size_t msglen;
	int retcode;
	// preparo la variabile msg in base alla dimensione del messaggio inserito dall'utente
	//msg = malloc(msg*sizeof(char));
	// apertura socket del client
	if ((client_socket = socket(PF_INET, SOCK_DGRAM, 0)) == -1)
		perror("Error in socket()");
		exit(-1);
	// preparazione dell'indirizzo del server con cui connettere il socket
	// connessione del socket al server
	if ((connect(client_socket, (struct sockaddr *)&server_addr, sizeof(server_addr))) == -1)
		perror("Error in connect()");
		exit(-1);
	printf("Client connected to %s\n", SERVERADDRESS);
	// invio messaggio al server
	msglen = strlen(msg)+1;
	retcode = send(client_socket, msg, msglen,0);
	printf("Sent %d (%u request) bytes on socket %d\n", retcode, (unsigned) msglen, client_socket);
When I try to run the Server application, I get this error "Error in server socket listen(): Operation not supported" I guess it's an error related to a wrong management of the UDP with connect().
Any suggestions?
Thanks in advance.
Previous Topic:Multiple Include Files Using Eclipse and MinGW
Next Topic:Can't run program on Eclipse!
Current Time: Mon Jul 07 23:55:30 EDT 2025
Powered by FUDForum. Page generated in 0.05963 seconds
