Moving class to a sub-package and synchronizing [message #1506229] |
Wed, 10 December 2014 12:39  |
I noticed the following behaviour:
If I have a model with base package p1, and (top-level) class A and a subpackage p2 and move A into p2, the .ecore and .genmodel files get updated correctly, and when I generate code from the .genmodel, then I obtain interface A inside p1.p2 and class AImpl inside p1.p2.impl as expected, but interface A and class AImpl are not removed from the top-level package p1.
Is this behaviour expected or is it a bug? It seems to be a bug, since the package reference to A gets removed from p1, the remaining class AImpl in p1 contains a compilation error:
Description Resource Path Location Type
A cannot be resolved or is not a field AImpl.java /eposse.experiments.ecoretools.ecttest/src/ecttest/impl line 36 Java Problem
I haven't found any reported bugs or forum messages describing this.
Also I noticed that whenever I'm creating a new class, the first time I generate code with that class I get an exception from Sirius:
Unable to load the resouce /.../p1/A.java
Unable to load the resouce /.../p1/impl/AImpl.java
It doesn't seem to have any adverse effects, but should this error be produced?
Re: Moving class to a sub-package and synchronizing [message #1506364 is a reply to message #1506229] |
Wed, 10 December 2014 15:13   |
Ernesto,
Comments below.
You should note I have many times described nested packages as syntactic
rat poison. If there were one thing I could still remove from Ecore
that would be it...
No generated file is ever removed. It may contain important
documentation or method implementations that you'd be upset to loose.
It's expected. There's no historical knowledge about what's been
generated in the past. So if you rename something the files with the
old name will continue to exist. With Ecore, you should generally do
any important Java refactoring before regenerating.
> Java Problem
There are dozens of ways to end up with this type of problem. Without
historical knowledge there's no knowledge about what might need to be
cleaned up.
Note that Xcore supports much nicer refactoring to avoid these kinds of
things, but it does not support nested packages; that's just a mistake I
won't repeat.
It's not specific to your moving between packages example.
I can't comment on what Sirius is doing....
> produced?
Perhaps these are exceptions that result from the files compiling with
errors, and of course you should delete the files. I don't think the
exceptions are really appropriate though so perhaps you want to report
that and see what the Sirius folks think.
Re: Moving class to a sub-package and synchronizing [message #1507705 is a reply to message #1506364] |
Thu, 11 December 2014 16:40  |
Hmm.
OK. I guess it makes sense, although it's a bit counter-intuitive: if you delete something from your model, usually the intention is to delete the generated code as well.
Anyway, regarding the other issue, it's not due to compile errors. It happens every time for every new class added. But it does sound like an issue with Sirius. I'll ask there.
FUDForum. Page generated in 0.26685 seconds
