Home » Eclipse Projects » GEF » figure with fixed width variable height
figure with fixed width variable height [message #150099] |
Wed, 08 September 2004 19:50  |
Hi, I'm trying to create a figure that'll have a flow layout. It has fixed
width, but the height is not fixed. The height is calculated based on the
children.
And it looked like the attached picture.
So my approach is like this, I was wondering if this approach is ok, or if
there is a better one.
So first you have a
PageFigure. PageFigure will draw a paper look a like thing using
graphics.fillRectangle, it uses XYLayout. Then PageFigure has a
ContentFigure. Then the ContentFigure uses a FlowLayout and figures can be
added to ContentFigure.
Basically I'm trying to create something that will look like an HTML Editor.
Please give comments on my approach
many thanks,
Michael
* The bound of this figure is set after the layout is done.
* The layout is done using ContentLayout which is a FlowLayout.
* It layouts the children with a flow layout.
* Then the bound is set:
* width=specifed fixed size,
* height=calculated based on its children height
public class ContentFigure extends Figure {
ContentLayout layoutManager;
int width;
public ContentFigure(int width) {
this.width = width;
setBackgroundColor(ColorConstants.white);
setOpaque(true);
layoutManager = new ContentLayout();
setLayoutManager(layoutManager);
// setBorder(new LineBorder(1));
* @return Returns the width.
public int getWidth() {
return width;
* @param width The width to set.
public void setWidth(int width) {
this.width = width;
/* (non-Javadoc)
* @see
org.eclipse.draw2d.Figure#getClientArea(org.eclipse.draw2d.g eometry.Rectangle)
public Rectangle getClientArea(Rectangle rect) {
Rectangle clientArea = super.getClientArea(rect);
println("ContentFigure.getClientArea" + clientArea);
if (clientArea.width > width)
clientArea.width = width;
return clientArea;
/* (non-Javadoc)
* @see org.eclipse.draw2d.Figure#layout()
protected void layout() {
Dimension dimension = layoutManager.getPreferredHeight(this,width);
println("ContentFigure.layout:"+dimension);
setBounds(new Rectangle(0,0,width,dimension.height));
layoutManager.layout(this);
* @param string
private void println(String string) {
System.out.println(string);
public class ContentLayout extends FlowLayout {
public ContentLayout() {
super();
setMajorSpacing(0);
setMinorSpacing(0);
/* (non-Javadoc)
* @see
org.eclipse.draw2d.AbstractLayout#getPreferredSize(org.eclip se.draw2d.IFigure,
int, int)
public Dimension getPreferredHeight(IFigure container, int wHint) {
return super.getPreferredSize(container, wHint, -1);
public class PageFigure extends Figure {
int pageWidth;
XYLayout layout;
ContentFigure contentFigure;
public PageFigure(int pageWidth) {
setOpaque(true);
layout = new XYLayout();
setLayoutManager(layout);
this.pageWidth = pageWidth;
contentFigure = new ContentFigure(pageWidth);
// contentFigure.setBorder(new LineBorder(1));
add(contentFigure);
/* (non-Javadoc)
* @see org.eclipse.draw2d.Figure#paintFigure(org.eclipse.draw2d.Gra phics)
protected void paintFigure(Graphics graphics) {
Rectangle bounds = getBounds();
System.out.println("PageFigure.paintFigure " + bounds);
graphics.setBackgroundColor(ColorConstants.gray);
graphics.fillRectangle(getBounds());
int x = (bounds.width - pageWidth)/2;
if (x < 0) x = 0;
int contentHeight = contentFigure.getBounds().height;
Rectangle contentBounds = new Rectangle(x,0,pageWidth,contentHeight);
contentFigure.setBounds(contentBounds);
// contentArea
// graphics.setBackgroundColor(ColorConstants.white);
// graphics.fillRectangle(contentBounds);
graphics.setBackgroundColor(ColorConstants.black);
graphics.fillRectangle(x-1,0,1,bounds.height);
graphics.fillRectangle(x+pageWidth,0,3,bounds.height);
graphics.setBackgroundColor(ColorConstants.lightGray);
graphics.fillRectangle(x,contentHeight,pageWidth,bounds.heig ht-contentHeight);
* @return Returns the pageWidth.
public int getPageWidth() {
return pageWidth;
* @param pageWidth The pageWidth to set.
public void setPageWidth(int pageWidth) {
* @return Returns the contentFigure.
public ContentFigure getContentFigure() {
return contentFigure;
Re: figure with fixed width variable height [message #150378 is a reply to message #150099] |
Thu, 09 September 2004 18:56   |
> So first you have a
Something different to try:
Let's call what you have as PageFigure a DocumentFigure. The DocumentFigure
can have one or more PageFigures (this is the actual visible page, including
empty space) in ToolbarLayout. Each PageFigure will have two children in a
border layout: a content figure (north) and a shaded figure (center), which
shades the empty space. As the content figure grows, the shaded figure
shrinks.
A better/simpler option would be to not have the shaded area. Then your
PageFigure can have the content figure in a stack layout. Adding stuff to
the content figure would work similar to adding parts to the FlowContainer
in the logic example. When you run out of space, you can add another
PageFigure to the DocumentFigure.
"Michael Permana" <mpermana@hotmail.com> wrote in message
news:cho5k9$5hf$1@eclipse.org...
> children.
> So first you have a
Editor.
> many thanks,
> Michael
> int width;
> this.width = width;
> setOpaque(true);
> return width;
> this.width = width;
> /* (non-Javadoc)
> * @see
e)
> return clientArea;
> /* (non-Javadoc)
> * @param string
> super();
> setMajorSpacing(0);
> setMinorSpacing(0);
> /* (non-Javadoc)
> * @see
e,
> int, int)
> int pageWidth;
> XYLayout layout;
> setOpaque(true);
> add(contentFigure);
> /* (non-Javadoc)
> if (x < 0) x = 0;
> // contentArea
> return pageWidth;
Re: figure with fixed width variable height [message #150387 is a reply to message #150378] |
Thu, 09 September 2004 19:00  |
Hmm, I didn't realize you were creating an HTML editor (just went by the
picture). In that case, why do you want your editor to look like Word
rather than FrontPage?
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:chqms7$8sd$1@eclipse.org...
> > So first you have a
be
DocumentFigure
including
a
which
> shrinks.
fixed
the
> > children.
if
> > So first you have a
be
> Editor.
> > many thanks,
> > Michael
> > int width;
> > this.width = width;
> > setOpaque(true);
> > return width;
> > this.width = width;
> > /* (non-Javadoc)
> > * @see
> e)
> > return clientArea;
> > /* (non-Javadoc)
> > * @param string
> > super();
> > setMajorSpacing(0);
> > setMinorSpacing(0);
> > /* (non-Javadoc)
> > * @see
> e,
> > int, int)
> > int pageWidth;
> > XYLayout layout;
> > setOpaque(true);
> > add(contentFigure);
> > /* (non-Javadoc)
> > * @see
> > if (x < 0) x = 0;
> > // contentArea
> > return pageWidth;
Current Time: Sat Jul 26 04:34:40 EDT 2025
Powered by FUDForum. Page generated in 0.05139 seconds
