Home » Newcomers » Newcomers » Launch Failure on WinXP
Launch Failure on WinXP [message #150252] Sat, 29 April 2006 00:50 Go to next message
Originally posted by: pydan.danshafer.com
I have NEVER successfully installed and run Eclipse, either on OS X or on
Windows. Tonight, I tried a completely clean install on my new Vaio. I
downloaded Eclipse for Windows, unzipped it and clicked on the Eclipse
icon. I get an error:
!SESSION Fri Apr 28 21:12:43 PDT 2006
!ENTRY org.eclipse.core.launcher 4 0 2006-04-28 21:12:43.937
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.RuntimeException: Could not find framework
at org.eclipse.core.launcher.Main.getBootPath(Main.java:635)
at org.eclipse.core.launcher.Main.basicRun(Main.java:272)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
As far as I can tell, I have the latest JRE installed, so this error
message is essentially useless to me.
Can anyone help with this or am I just missing something really obvious?
dan
Re: Launch Failure on WinXP [message #150305 is a reply to message #150252] Sat, 29 April 2006 09:47 Go to previous messageGo to next message
Are you sure you have a Java Runtime Environment installed or Java
Development Kit? If you do double check the CLASSPATH environment
variable. Finally, make sure you have the right version of the JRE or JDK.
Re: Launch Failure on WinXP [message #150341 is a reply to message #150252] Sat, 29 April 2006 14:44 Go to previous message
Dan,
This error usually means your zip program did not extract the Eclipse
archive properly. Make sure you choose the option to maintain the
directory structure when extracting Eclipse. It should create an
eclipse folder, with plugins and fragments folders below it.
- Jeff
Previous Topic:can't lauch eclipse under centOS
Next Topic:HTTP 404 Not Found with Help Contents
Current Time: Fri Jul 18 13:00:25 EDT 2025
Powered by FUDForum. Page generated in 0.08336 seconds
