| Debugging Inner Class on M7 [message #150223] |
Tue, 23 March 2004 08:55  |
Originally posted by: l.forni.inwind.it
I noticed a problem when i debug an RCP (any app) with eclipse M7
I have to rebuild the project and restart it if i want to see any
modification in source code of an inner class.
Hot code replacement works well in debug on a normal java class.
Anyone has noticed the same behaviour?
Thanx
| Re: Debugging Inner Class on M7 [message #150389 is a reply to message #150310] |
Wed, 24 March 2004 11:02   |
I made some test to have a simple test case, but i found that hotcode
replacement works well debugging simple inner class.
But i noticed that sometimes eclipse doesn't make build on changed resourced
debugging inner class in my application .
Infact if i press CTRL+b during debug, hotcode replacement works.
I'm sorry but i don't know how to make a reproducible test case because i
don't understand what the cause is.
Thanx anyway.
"Darin Swanson" <Darin_Swanson@us.ibm.com> ha scritto nel messaggio
news:c3s1m7$mt9$1@eclipse.org...
> Log a bug report with a reproducible test case against JDT Debug
> Darins
> "Luca Forni" <l.forni@inwind.it> wrote in message
> news:c3roqr$cei$3@eclipse.org...
> > Hi,
> > I've made the same debug in eclipse 2.1.1 and eclipse M7 with the same
vm
> > (1.4.2_03).
> > When i make a change in source code of an inner class, eclipse 2.1.1
works
> > well, but M7 doesn't take the changes.
> > So i think it is an eclipse problem.
> > "exquisitus" <user@domain.invalid> ha scritto nel messaggio
> > news:c3ptms$a8v$1@eclipse.org...
> > > Luca,
> > > M7, XP, 1.4.2_04 I'm not have the same problems. Hot swap works fine
if
> > > you don't change the method signature of ANY method in the class.
> > > If that's not what you are seeing, carefully read the failure dialog.
> > > If the vm rejected the change, the issue is in your VM not eclipse.
> > > > Thanx
| Re: Debugging Inner Class on M7 [message #150397 is a reply to message #150389] |
Wed, 24 March 2004 11:13   |
If you have turned off "Perform build automatically on resource
modification" no build will occur when a resource is changed.
Ctrl-B is enabled when "Perform build automatically on resource
modification" (autobuild) is turned off.
HTH
Darins
news:c3sb6f$43p$1@eclipse.org...
resourced
> Thanx anyway.
> > Darins
> > > Hi,
> vm
> > > (1.4.2_03).
> works
> > > > Luca,
fine
> if
dialog.
> > > > > Thanx
| Re: Debugging Inner Class on M7 [message #150436 is a reply to message #150397] |
Wed, 24 March 2004 12:14  |
When i made tests i had "Perform build automatically on resource
modification" turned on.
Infact hotcode replacement mostly works except for this strange behavior
with inner class in my big project.
Luca
news:c3sbha$4je$1@eclipse.org...
> HTH
> Darins
> resourced
i
> > Thanx anyway.
> > > Darins
> > > > Hi,
same
> > vm
> > > > (1.4.2_03).
> > works
> > > > > Luca,
> fine
> > if
> dialog.
eclipse.
M7
any
> > > > > > Thanx
FUDForum. Page generated in 0.03168 seconds
