Home » Newcomers » Newcomers » CVS Plug In
CVS Plug In [message #150104] Thu, 27 April 2006 18:03 Go to next message
Originally posted by: mgandikota.membersedgellc.com
I am looking for info on
- where is the CVS (file repository) plug in?
- how to set up Eclipse so that it talks to the CVS server
- how to update files in CVS from Eclipse IDE
I am novice at Eclipse and will appreciate answers from
the knowledgeable people.
Murthy
Re: CVS Plug In [message #150137 is a reply to message #150104] Fri, 28 April 2006 04:03 Go to previous messageGo to next message
The Perspective to browse CVS and create connections to repositories is:
Window > Open Perspective > CVS Repository Exploring
Another possibility is to edit your settings with:
Window > Preferences... > Team
Jan
"murthy" <mgandikota@membersedgellc.com> schrieb im Newsbeitrag
news:b6a95a82bcb681b0743f3e171269ba46$1@www.eclipse.org...
> Hi
> Thanks
> Murthy
Re: CVS Plug In [message #150154 is a reply to message #150137] Fri, 28 April 2006 09:12 Go to previous message
If you are new to Eclipse it might help to look through a tutorial.
Luckily one is provided with Eclipse. Go to Help->Help Contents with the
window that appears go to Workbench User Guide -> Getting started -> Team
CVS tutorial. Note: the tutorial assumes that you are familiar with the
fundamentals of CVS.
Previous Topic:"Unhandled event loop exception" when attempting to run Java app
Next Topic:Plug-in Dev Doc for 3.1/3.2
Current Time: Tue Jul 22 09:00:14 EDT 2025
Powered by FUDForum. Page generated in 0.19451 seconds
