Home » Newcomers » Newcomers » "Unhandled event loop exception" when attempting to run Java app
"Unhandled event loop exception" when attempting to run Java app [message #150052] Thu, 27 April 2006 15:34 Go to next message
Platform: Intel Pentium M, ubuntu 5.10 Breezy Badger,
eclipse 3.1.1-1ubuntu3,
Blackdown Java SDK j2sdk1.4 1.4.2.03-1
I've created the file Hello.java in an eclipse workspace named
hello_world.
Hello.java looks like this:
public class Hello {
* @param args
// TODO Auto-generated method stub
System.out.println("Hello world!");
When I open the RMBM on Hello.java and select
Run As->Java Application
I get an "Unhandled event loop exception" error in the error log.
The full details on this entry is:
An exception stack trace is not available.
It's followed by an entry with the title "Failed to execute runnable
(java.lang.NullPointerException)" in the error log.
Is this the wrong way to execute a Java program? Or is there
something wrong with my program or my setup?
Thanx!
- Steinar
The full details for the "Failed to execute runnable
(java.lang.NullPointerException)" error log message, is:
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException)
at org.eclipse.swt.SWT.error(int, java.lang.Throwable, java.lang.String) (Unknown Source)
at org.eclipse.swt.SWT.error(int, java.lang.Throwable) (Unknown Source)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(boolea n) (Unknown Source)
at org.eclipse.swt.widgets.Display.runAsyncMessages(boolean) (Unknown Source)
at org.eclipse.swt.widgets.Display.readAndDispatch() (Unknown Source)
at org.eclipse.ui.internal.Workbench.runEventLoop(org.eclipse.j face.window.Window$IExceptionHandler, org.eclipse.swt.widgets.Display) (Unknown Source)
at org.eclipse.ui.internal.Workbench.runUI() (Unknown Source)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(org. eclipse.swt.widgets.Display, org.eclipse.ui.application.WorkbenchAdvisor) (Unknown Source)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(org.eclipse. swt.widgets.Display, org.eclipse.ui.application.WorkbenchAdvisor) (Unknown Source)
at org.eclipse.ui.internal.ide.IDEApplication.run(java.lang.Obj ect) (Unknown Source)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(ja va.lang.Object) (Unknown Source)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(java.lan g.Object) (Unknown Source)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(java.lan g.String[], java.lang.Runnable) (Unknown Source)
at java.lang.reflect.Method.invoke(java.lang.Object, java.lang.Object[]) (/usr/lib/libgcj.so.6.0.0)
at org.eclipse.core.launcher.Main.invokeFramework(java.lang.Str ing[], java.net.URL[]) (Unknown Source)
at org.eclipse.core.launcher.Main.basicRun(java.lang.String[]) (Unknown Source)
at org.eclipse.core.launcher.Main.run(java.lang.String[]) (Unknown Source)
at org.eclipse.core.launcher.Main.main(java.lang.String[]) (Unknown Source)
at gnu.java.lang.MainThread.call_main() (/usr/lib/libgcj.so.6.0.0)
at gnu.java.lang.MainThread.run() (/usr/lib/libgcj.so.6.0.0)
at org.eclipse.ui.part.PageBookView.showPageRec(org.eclipse.ui. part.PageBookView$PageRec) (Unknown Source)
at org.eclipse.ui.internal.console.ConsoleView.showPageRec(org. eclipse.ui.part.PageBookView$PageRec) (Unknown Source)
at org.eclipse.ui.part.PageBookView.partActivated(org.eclipse.u i.IWorkbenchPart) (Unknown Source)
at org.eclipse.ui.internal.console.ConsoleView.display(org.ecli pse.ui.console.IConsole) (Unknown Source)
at org.eclipse.ui.internal.console.ConsoleManager$1.run() (Unknown Source)
at org.eclipse.swt.widgets.RunnableLock.run() (Unknown Source)
...18 more
Re: "Unhandled event loop exception" when attempting to run Java app [message #150143 is a reply to message #150052] Fri, 28 April 2006 04:22 Go to previous message
I started eclipse with
eclipse -clean
and my problems went away. I'm now both able to run and debug my
troublesome applications.
Previous Topic:Access path relative to plugin installation directory
Next Topic:CVS Plug In
Current Time: Tue Jul 22 02:01:45 EDT 2025
Powered by FUDForum. Page generated in 0.54354 seconds
