Home » Modeling » OCL » OCLinEcore Problem
OCLinEcore Problem [message #1499775] Fri, 05 December 2014 06:55 Go to next message
I have added a set of ocl constraints to my metamodel (OCLinEcore) in order to
generate an editor and export the "Deployable plug-ins and fragments". If I run the editor, the OCL constrains works well, but, if I generate the plugins, install them in Eclipse and try to validate some diagram, an error occurs: "An exception occurred while delegating evaluation for the <invariant_name> constraint on <class_name>: java.lang.IllegalStateException:nul".
Do you guys know how can I solve this?
Re: OCLinEcore Problem [message #1499928 is a reply to message #1499775] Fri, 05 December 2014 09:30 Go to previous messageGo to next message
Probably, but since you decline to take any notice of
https://wiki.eclipse.org/OCL/ForumNetiquette
that I referred you to previously, you probably won't understand why I
cannot help.
Ed Willink
On 05/12/2014 11:55, Bruno Costa wrote:
> order to generate an editor and export the "Deployable plug-ins and
Re: OCLinEcore Problem [message #1500088 is a reply to message #1499928] Fri, 05 December 2014 12:29 Go to previous messageGo to next message
I read the OCL/ForumNetiquette... you need more details about my problem, right?
Well, about Eclipse: Eclipse Modeling Tools; Version: Luna Service Release 1 (4.4.1); Build id: 20140925-1800. OCL Examples and Editors SDK 3.4.0.v20140609-1793. Run configurations: -XX:PermSize=64M -XX:MaxPermSize=128M -Xms512M -Xmx1024M
I think is that...
Re: OCLinEcore Problem [message #1500097 is a reply to message #1500088] Fri, 05 December 2014 12:38 Go to previous messageGo to next message
Read it again.
If you can't figure it out, I won't be able to help you, and you should
look for another hobby/profession.
Ed Willink
> problem, right? Well, about Eclipse: Eclipse Modeling Tools; Version:
> I think is that...
Re: OCLinEcore Problem [message #1500120 is a reply to message #1500097] Fri, 05 December 2014 13:02 Go to previous message
Hi Edward,
I've read it and understood it completely Smile
It's just that with the information that I provided maybe someone that already faced the same problem could rapidly answer (as many other topics and forums). But OK, I appreciate your tip. I'll let the question open for a while if someone has already faced it. After, when I have more time, I will provide all information requested in OCL/ForumNetiquette.
Thank you for your attention.
[Updated on: Fri, 05 December 2014 13:36] by Moderator
Previous Topic:Problem with Generated editor and ocl constraints
Next Topic:Valuation of forAll in combination with @pre and check of vanished items
Current Time: Thu Jul 24 11:22:34 EDT 2025
Powered by FUDForum. Page generated in 0.06425 seconds
