Problem with Generated editor and ocl constraints [message #552606] |
Thu, 12 August 2010 14:28  |
I have added a set of ocl constraints to my metamodel in order to
generate an editor. The question is that when I test the editor in a new
instance of Eclipse (running it as an Eclipse application) the
validation works perfectly. However, when I export the plugins,
generating the corresponding .jar and I install them in Eclipse,
validations do not work.
I think I'm missing something when generating the editor plugins,
could anyone give me a hint?
P.D: I'm using the OclinEcore helios plugin.
Thanks in advance,
Toñi
Re: Problem with Generated editor and ocl constraints [message #552793 is a reply to message #552611] |
Fri, 13 August 2010 10:14   |
Thx, I have solved it adding dependencies to ocl.ecore validation a
validation.ocl
El 12/08/2010 21:39, Ed Willink escribió:
> Hi Toni
> I'm not clear what 'validations' you mean.
> OCLinEcore will allow you to enrich an Ecore meta-model, so
> presumably your installed code is just an EMF plugin.
> So most likely you haven't got ...ocl.ecore.
> Are you sure it works non-reflectively? Did you set Operation Reflection
> true in genmodel?
> Ed
> On 12/08/2010 19:28, Toñi Reina Quintero wrote:
>> Hi,
>> I think I'm missing something when generating the editor plugins, could
>> Thanks in advance,
>> Toñi
FUDForum. Page generated in 0.04821 seconds
