Home » Language IDEs » Java Development Tools (JDT) » random java.lang.IllegalStateException with Eclipse 4.4 and java 8
random java.lang.IllegalStateException with Eclipse 4.4 and java 8 [message #1442241] Fri, 10 October 2014 17:04 Go to next message
I have random compiler exception.
Sometimes, modifying a file, then Eclipse recompile fine, other times I need to do a clean and rebuild
below the exception:
eclipse.buildId=4.4.1.M20140925-0400
java.version=1.8.0_20
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=it_IT
org.eclipse.jdt.core
Error
Fri Oct 10 22:45:58 CEST 2014
Errors running builder 'Java Builder' on project 'ntools'.
	at org.eclipse.jdt.internal.compiler.lookup.TypeSystem.cacheDerivedType(TypeSystem.java:268)
	at org.eclipse.jdt.internal.compiler.lookup.TypeSystem.cacheDerivedType(TypeSystem.java:298)
	at org.eclipse.jdt.internal.compiler.lookup.AnnotatableTypeSystem.getArrayType(AnnotatableTypeSystem.java:87)
	at org.eclipse.jdt.internal.compiler.lookup.LookupEnvironment.getTypeFromSignature(LookupEnvironment.java:1323)
	at org.eclipse.jdt.internal.compiler.lookup.BinaryTypeBinding.createFields(BinaryTypeBinding.java:547)
	at org.eclipse.jdt.internal.compiler.lookup.BinaryTypeBinding.cachePartsFrom(BinaryTypeBinding.java:473)
	at org.eclipse.jdt.internal.compiler.lookup.LookupEnvironment.createBinaryTypeFrom(LookupEnvironment.java:696)
	at org.eclipse.jdt.internal.compiler.lookup.LookupEnvironment.createBinaryTypeFrom(LookupEnvironment.java:679)
	at org.eclipse.jdt.internal.compiler.Compiler.accept(Compiler.java:299)
	at org.eclipse.jdt.internal.compiler.lookup.LookupEnvironment.askForType(LookupEnvironment.java:164)
	at org.eclipse.jdt.internal.compiler.lookup.PackageBinding.getTypeOrPackage(PackageBinding.java:201)
	at org.eclipse.jdt.internal.compiler.lookup.CompilationUnitScope.findImport(CompilationUnitScope.java:468)
	at org.eclipse.jdt.internal.compiler.lookup.CompilationUnitScope.findSingleImport(CompilationUnitScope.java:522)
	at org.eclipse.jdt.internal.compiler.lookup.CompilationUnitScope.resolveSingleImport(CompilationUnitScope.java:735)
	at org.eclipse.jdt.internal.compiler.lookup.Scope.getTypeOrPackage(Scope.java:3310)
	at org.eclipse.jdt.internal.compiler.lookup.Scope.getType(Scope.java:3042)
	at org.eclipse.jdt.internal.compiler.ast.SingleTypeReference.getTypeBinding(SingleTypeReference.java:51)
	at org.eclipse.jdt.internal.compiler.ast.TypeReference.internalResolveType(TypeReference.java:472)
	at org.eclipse.jdt.internal.compiler.ast.TypeReference.resolveType(TypeReference.java:571)
	at org.eclipse.jdt.internal.compiler.ast.TypeReference.resolveType(TypeReference.java:567)
	at org.eclipse.jdt.internal.compiler.ast.TypeReference.resolveSuperType(TypeReference.java:541)
	at org.eclipse.jdt.internal.compiler.lookup.ClassScope.findSupertype(ClassScope.java:1287)
	at org.eclipse.jdt.internal.compiler.lookup.ClassScope.connectSuperInterfaces(ClassScope.java:1038)
	at org.eclipse.jdt.internal.compiler.lookup.ClassScope.connectTypeHierarchy(ClassScope.java:1096)
	at org.eclipse.jdt.internal.compiler.lookup.ClassScope.connectMemberTypes(ClassScope.java:906)
	at org.eclipse.jdt.internal.compiler.lookup.ClassScope.connectTypeHierarchy(ClassScope.java:1104)
	at org.eclipse.jdt.internal.compiler.lookup.CompilationUnitScope.connectTypeHierarchy(CompilationUnitScope.java:323)
	at org.eclipse.jdt.internal.compiler.lookup.LookupEnvironment.completeTypeBindings(LookupEnvironment.java:227)
	at org.eclipse.jdt.internal.compiler.Compiler.internalBeginToCompile(Compiler.java:746)
	at org.eclipse.jdt.internal.compiler.Compiler.beginToCompile(Compiler.java:383)
	at org.eclipse.jdt.internal.compiler.Compiler.compile(Compiler.java:428)
	at org.eclipse.jdt.internal.core.builder.AbstractImageBuilder.compile(AbstractImageBuilder.java:367)
	at org.eclipse.jdt.internal.core.builder.IncrementalImageBuilder.compile(IncrementalImageBuilder.java:330)
	at org.eclipse.jdt.internal.core.builder.AbstractImageBuilder.compile(AbstractImageBuilder.java:304)
	at org.eclipse.jdt.internal.core.builder.IncrementalImageBuilder.build(IncrementalImageBuilder.java:135)
	at org.eclipse.jdt.internal.core.builder.JavaBuilder.buildDeltas(JavaBuilder.java:267)
	at org.eclipse.jdt.internal.core.builder.JavaBuilder.build(JavaBuilder.java:195)
	at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:734)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:206)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:246)
	at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:299)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:302)
	at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:358)
	at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:381)
	at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
	at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Re: random java.lang.IllegalStateException with Eclipse 4.4 and java 8 [message #1442419 is a reply to message #1442241] Fri, 10 October 2014 23:52 Go to previous messageGo to next message
Please file a bug report in Bugzilla.
Is this issue reproducible. A test case would greatly help.
Could you also try out 4.5 M2.
Re: random java.lang.IllegalStateException with Eclipse 4.4 and java 8 [message #1442426 is a reply to message #1442419] Sat, 11 October 2014 00:08 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=420284
Re: random java.lang.IllegalStateException with Eclipse 4.4 and java 8 [message #1442432 is a reply to message #1442426] Sat, 11 October 2014 00:16 Go to previous messageGo to next message
Sorry. Please ignore the bug ID.
Re: random java.lang.IllegalStateException with Eclipse 4.4 and java 8 [message #1442435 is a reply to message #1442432] Sat, 11 October 2014 00:21 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=446715
Re: random java.lang.IllegalStateException with Eclipse 4.4 and java 8 [message #1442641 is a reply to message #1442435] Sat, 11 October 2014 08:18 Go to previous messageGo to next message
I don't know how to reproduce, because the error appears random (but very often) in a big project.
I've noticed, however, the errors started first times when I started using Eclipse 4.4 with the new "null Analysis"
If you need some info, I'll try to get you
thanks
Re: random java.lang.IllegalStateException with Eclipse 4.4 and java 8 [message #1442993 is a reply to message #1442641] Sat, 11 October 2014 21:29 Go to previous messageGo to next message
Let us take the discussion on Bugzilla. Please add yourself to the notification list.
Re: random java.lang.IllegalStateException with Eclipse 4.4 and java 8 [message #1499537 is a reply to message #1442993] Fri, 05 December 2014 02:55 Go to previous message
Hi. Maybe the Java environment or Java application is not in an appropriate state for the requested operation....
Previous Topic:Help me! This is so weird! (Java Thread error)
Next Topic:Problem by resolving typs by HalloWorld
Current Time: Mon Sep 01 00:03:36 EDT 2025
Powered by FUDForum. Page generated in 0.05261 seconds
