| How to use the IMoveDeleteHook [message #148562] |
Thu, 23 October 2003 12:07  |
Originally posted by: mharp.seapine.com
Can someone explain to me how to use this? It appears that the CVS plugin
supports it, but I do the same thing and my stuff never gets called.
I've got this block in my plugin.xml
<extension point="org.eclipse.core.resources.moveDeleteHook">
<moveDeleteHook class="com.foo.MyMoveDeleteHook" />
</extension>
and I return a static instance of com.foo.MyMoveDeleteHook from the
RepositoryProvider.getMoveDeleteHook() method, but that method never gets
called, and none of the IMoveDeleteHooks methods I override in
MyMoveDeleteHook get called either.
I'm not sure what else I'm supposed to be doing to get Eclipse 2.1.1 to
recognize my hook...
Any help would be greatly appreciated.
harpstein
| Re: How to use the IMoveDeleteHook [message #149921 is a reply to message #149819] |
Mon, 27 October 2003 16:53  |
Thanks for the reply. I was just about to say that I've done all that and it
still doesn't work, but then I realized I overrode the method on my
AbstractUIPlugin class instead of the RepositoryProvider.
Dumb me,
harpstein
"Michael Valenta" <Michael_Valenta@oti.com> wrote in message
news:3F9D6921.7050806@oti.com...
> This hook is only for use by repository providers. The requirments are
> 1) The repository provider returns the hook from getMoveDeleteHook()
> (which you've done).
> 2) One or more projects hev been mapped to the repository provider using
> the RepositoryProvider.map() static method.
> One these two things are done, any move s or deletes in the mapped
> project will invoke the move/delete hook for that provider.
> Michael
plugin
> > </extension>
gets
> > Thanks,
> > harpstein
FUDForum. Page generated in 0.03392 seconds
