Home » Eclipse Projects » Eclipse Platform » How to use the IMoveDeleteHook
How to use the IMoveDeleteHook [message #148562] Thu, 23 October 2003 12:07 Go to next message
Originally posted by: mharp.seapine.com
Can someone explain to me how to use this? It appears that the CVS plugin
supports it, but I do the same thing and my stuff never gets called.
I've got this block in my plugin.xml
<extension point="org.eclipse.core.resources.moveDeleteHook">
<moveDeleteHook class="com.foo.MyMoveDeleteHook" />
</extension>
and I return a static instance of com.foo.MyMoveDeleteHook from the
RepositoryProvider.getMoveDeleteHook() method, but that method never gets
called, and none of the IMoveDeleteHooks methods I override in
MyMoveDeleteHook get called either.
I'm not sure what else I'm supposed to be doing to get Eclipse 2.1.1 to
recognize my hook...
Any help would be greatly appreciated.
harpstein
Re: How to use the IMoveDeleteHook [message #149819 is a reply to message #148562] Mon, 27 October 2003 13:51 Go to previous messageGo to next message
Originally posted by: Michael_Valenta.oti.com
This hook is only for use by repository providers. The requirments are
1) The repository provider returns the hook from getMoveDeleteHook()
(which you've done).
2) One or more projects hev been mapped to the repository provider using
the RepositoryProvider.map() static method.
One these two things are done, any move s or deletes in the mapped
project will invoke the move/delete hook for that provider.
Michael
> </extension>
> harpstein
Re: How to use the IMoveDeleteHook [message #149921 is a reply to message #149819] Mon, 27 October 2003 16:53 Go to previous message
Thanks for the reply. I was just about to say that I've done all that and it
still doesn't work, but then I realized I overrode the method on my
AbstractUIPlugin class instead of the RepositoryProvider.
Dumb me,
harpstein
"Michael Valenta" <Michael_Valenta@oti.com> wrote in message
news:3F9D6921.7050806@oti.com...
> Michael
plugin
> > </extension>
gets
> > Thanks,
> > harpstein
Previous Topic:NoClassDefFound
Next Topic:Class not found
Current Time: Wed Sep 17 02:09:14 EDT 2025
Powered by FUDForum. Page generated in 0.02661 seconds
