Home » Archived » Sapphire » How to declare and set an integer field in Sapphire?
How to declare and set an integer field in Sapphire? [message #1497218] Wed, 03 December 2014 11:46 Go to next message
Hello!
I have following model:
public interface IMyModel extends Element {
	ElementType TYPE = new ElementType(IMyModel.class);
	@Label(standard = "Integer field")
	@Required
	@NumericRange(min="2", max="100000")
	ValueProperty PROP_INTEGER_FIELD = new ValueProperty(TYPE, "IntegerField");
	Value<Integer> getIntegerField();
	void setIntegerField(Integer integerField);
When I run the following code, I get an UnsupportedOperationException.
final IMyModel object = IMyModel.TYPE.instantiate();
object.setIntegerField(10);
What is the right way to declare and set an integer field?
Thanks in advance
Dmitri Pisarenko
Re: How to declare and set an integer field in Sapphire? [message #1497236 is a reply to message #1497218] Wed, 03 December 2014 12:05 Go to previous messageGo to next message
You are missing the @Type annotation that declares the type held by the property. By default, a value property holds a string value.
@Type( base = Integer.class )
Sapphire SDK includes a number of code templates to make these blocks easier to write. Simply type "sf" + space to see the available templates.
index.php/fa/20130/0/
  • Attachment: Capture2.PNG
    (Size: 54.37KB, Downloaded 585 times)
[Updated on: Wed, 03 December 2014 12:06] by Moderator
Re: How to declare and set an integer field in Sapphire? [message #1498155 is a reply to message #1497236] Thu, 04 December 2014 03:04 Go to previous messageGo to next message
Thanks!
Re: How to declare and set an integer field in Sapphire? [message #1498156 is a reply to message #1497236] Thu, 04 December 2014 03:05 Go to previous message
Thanks!
Previous Topic:What is the best way to add tree node for an optional xml child element?
Next Topic:On using PossibleValuesService for dynamically changed list of values
Current Time: Tue Oct 28 23:39:10 EDT 2025
Powered by FUDForum. Page generated in 0.03857 seconds
