Home » Language IDEs » Java Development Tools (JDT) » Run Application using Ant and Debug using Eclipse
Run Application using Ant and Debug using Eclipse [message #149681] Thu, 18 March 2004 12:57 Go to next message
Hi-
This may seem strange..but I have a build.xml that can run the Java
Application using java task of Ant. Once the Application runs I want to
remote debug using Eclipse...basically I want to attach Eclipse debugger
to this.
Is this possible? Would It help if I start Ant build through Eclipse? I
doubt ...but let me know your views.
Re: Run Application using Ant and Debug using Eclipse [message #149691 is a reply to message #149681] Thu, 18 March 2004 13:15 Go to previous messageGo to next message
You could start the Ant build via Eclipse but that would not help....but
that definitely has the cool factor :-)
You need to specify the correct VM args to the application that you are
starting from Ant.
So set your java task to fork and then use the nested <jvmarg> element(s) to
specify
something like:
<java classname="test.Main"
fork="yes" >
<jvmarg value="-Xdebug"/>
<jvmarg value="-Xnoagent"/>
<jvmarg value="-Djava.compiler=NONE"/>
<jvmarg
value=" -Xrunjdwp:transport=dt_socket,server=y,suspend=y,address=800 0 "/>
</java>
HTH
Darins
"rohitsoftware" <rohitsoftware@yahoo.com> wrote in message
news:c3cnth$1vq$1@eclipse.org...
> Hi-
> to this.
Re: Run Application using Ant and Debug using Eclipse [message #149709 is a reply to message #149691] Thu, 18 March 2004 14:13 Go to previous messageGo to next message
> starting from Ant.
> specify
> something like:
> fork="yes" >
> <jvmarg
> </java>
> HTH
> Darins
> > Hi-
> > to this.
The reason I was doubtful about this was because Ant Manual states-
If odd things go wrong when you run this task, set fork="true" to use a
new JVM.
Note that you cannot interact with a forked VM, the only way to send input
to it is via the input and inputstring attributes.
Do you still think this will work?
Thanks.
Re: Run Application using Ant and Debug using Eclipse [message #149727 is a reply to message #149709] Thu, 18 March 2004 14:30 Go to previous messageGo to next message
> new JVM.
> Thanks.
Try it and let us know :-)
Re: Run Application using Ant and Debug using Eclipse [message #149748 is a reply to message #149727] Thu, 18 March 2004 14:44 Go to previous messageGo to next message
> > new JVM.
> > Thanks.
It doesn't.
This is the core problem:
The classpath is too big to fit in DOS of Windows 2000.
The Eclipse Console doesn't allow to save seperately stdout and stderr in
file format. That's a bug ...but till now it doesn't.
I need the output to be saved while running in a seperate file.
I got Ant to run it. It takes care of both the above problems. But then I
cannot connect remotely using Eclipse Debugger? I am stuck. Is there a way
to solve the above problems and connect the App using Eclipse Debugger.
Re: Run Application using Ant and Debug using Eclipse [message #149756 is a reply to message #149748] Thu, 18 March 2004 15:30 Go to previous messageGo to next message
news:c3cu70$a0a$1@eclipse.org...
a
> > > new JVM.
input
> > > Thanks.
> It doesn't.
Well I just tried running a program from an Ant buildfile and then connected
to it with Eclipse..worked great.
My test:
<project default="remote">
<target name="remote">
<java classname="B" fork="true">
<classpath>
<pathelement path="bin" />
</classpath>
<jvmarg value="-Xdebug" />
<jvmarg value="-Xnoagent" />
<jvmarg value="-Djava.compiler=NONE" />
<jvmarg
value=" -Xrunjdwp:transport=dt_socket,server=y,suspend=y,address=800 0 " />
</java>
</target>
</project>
Set some breakpoints in the code that you wish to debug
I launched this Ant build in Eclipse.
Then I went Run>Debug...>Remote Java Application>New
Set the project (this is not required)
Debug
Darins
Re: Run Application using Ant and Debug using Eclipse [message #149785 is a reply to message #149756] Thu, 18 March 2004 16:16 Go to previous message
> a
> > > > new JVM.
> input
> > > > Thanks.
> > It doesn't.
> My test:
> <classpath>
> </classpath>
> <jvmarg
> </java>
> </target>
> </project>
> Debug
> Darins
I launched the Ant build outside Eclipse and tried with address=8000.
Earlier was using 5000. May be 5000 was a problem. Also, since my app
takes long to start I connected Eclipse pretty much after starting Ant. It
shows some threads and picked up.
Thanks.
Previous Topic:Java VM crash & IOException debugging
Next Topic:Possible to show the Java command on console?
Current Time: Fri Nov 07 02:21:59 EST 2025
Powered by FUDForum. Page generated in 0.03995 seconds
