Home » Modeling » EMF » How do I programmatically select an EMF element in the Project Explorer?(Coordinating EMF selection with Project Explorer selection)
How do I programmatically select an EMF element in the Project Explorer? [message #1497128] Wed, 03 December 2014 10:09 Go to next message
Given an element selected in the EMF editor, I want to select the corresponding element in the Project Explorer. I have tried two approaches so far, neither of which has worked.
Approach 1: Extend the Navigate->Show In->Project Explorer functionality. Here I have modified the EMF Editor's IShowInSource. getShowInContext() to return the model element, but the Project Explorer does not understand that selection nor can I figure out how to configure it to map that selection into an actual element of the tree.
Approach 2: Create a new operation (pop-up menu) to perform this action. Here I am struggling with the implementation of the handler. Given the model element, how do I locate the corresponding tree node in the Project Explorer?
Can anyone help me with either of these approaches (or offer a third alternative)?
Re: How do I programmatically select an EMF element in the Project Explorer? [message #1504501 is a reply to message #1497128] Tue, 09 December 2014 05:03 Go to previous message
Paul,
I don't have significant experience with the common navigator
framework. Is the tree for your model actually shown in the Project
explorer? More comments below.
Keep in mind that it may well be the case that the explorer is showing
different objects (from a different resource set) than is the editor
itself (depending on whether your using the transaction framework to
share editing domains.
The issue with the editor and the explore using different objects could
well be a problem here, but as I said, I don't understand the details of
how the project explorer works. That's why I ask if your model is
actually showing children in the explorer. If so you must have done
something to make that work....
Also a good question, but it's similar to approach 1 where you've
returned the selection in the editor, but the outline in the explorer is
likely using different object instances than in the editor...
> alternative)?
I have no deep experience. Hopefully someone else will suggest something...
Previous Topic:CWM usage in EMF
Next Topic:Error while running my Eclipse application
Current Time: Fri Jul 25 21:37:51 EDT 2025
Powered by FUDForum. Page generated in 0.05430 seconds
