| Home » Eclipse Projects » GEF » coordinate system/documentation
 Goto Forum:|
| coordinate system/documentation [message #148972] | Mon, 30 August 2004 10:56  |  |
| Eclipse User  |  |  |  |  | Hello,
 I'm new to the gef/draw2d drawing API and have some problems finding my way.
 Furthermore I haven't used java mechanisms to paint anything, yet. So I
 might miss some
 seemingly obvious points.
 I managed to build a GEF Editor with the corresponding model and my figures
 are getting
 painted. Well - kind of.
 According to sizes and coordinates I'm still stepping in the dark. I
 couldn't find any explanation
 in the documentation about coordinate systems. Neither did a Google search
 help.
 I'd like to know which units draw2d uses for its coordinate and size values.
 And the prefered way to map from real-world coordinates to the logical
 coordinate system used by draw2d.
 Can anyone point me to some documentation regarding this area? Or can anyone
 give me some tips what to do?
 Thanks in advance!
 Bernd
| Re: coordinate system/documentation [message #149251 is a reply to message #149026] | Tue, 31 August 2004 13:49   |  |
| Eclipse User  |  |  |  |  | My pleasure :-)
 My model represents a simple CAD part of rectangular shape, with a bunch of
 child parts (actually: holes in the part).
 The model coordinates are in Millimetres.
 Initially, I want my whole models figure to be visible (without scrollbars).
 Later, the user should be able to Zoom and Scroll, as he wishes.
 Rulers in millimetres at the top and left side of the editor pane would be
 nice.
 I know the phyical boundaries of my model (a rectangle: physicalBounds).
 So, I guess I need to scale from my physical coordinates to the logical
 (pixel) coordinates.
 Again guessing, I would have to get the current boundaries of my canvas.
 Probably by calling
 Rectangle clientRect= getClientArea()
 on the figure in the topmost edit part (Or is there a better way?) .
 Now I can compute my scaling factors:
 double scaleY= clientRect.height / physicalBounds.height
 double scaleX= clientRect.width / physicalBounds.width
 Now, what to do with these factors?
 Probably each time I update my parts from the model (updateVisuals() or some
 such),
 I would have to apply the scaling factors to get from model physcal
 coordinates to model logical coordinates.
 somefigure.x= cadThing.x * scaleX
 somefigure.y= cadThing.y * scaleY
 That is a bit uncomfortable. It would be much nicer to tell the canvas, that
 each coordinate that I use is in fact
 a physical coordinate, which needes to be scaled or otherwise translated to
 screen coordinates (pixels)
 before the actual painting takes place.
 The win32 API (GDI Drawing Decice Context, represented by the MFC class CDC)
 offers methods to set up
 a physical to logical mapping using setMapMode(), setWindowExt() and
 setViewportExt() methods.
 Is there something similar in draw2d? Or java2d (which I guess could be
 brought into play using the holongate.org plugin)?
 Can you make anything of this? Or am I barking up the wrong tree?
 Bernd
 "Randy Hudson" <none@us.ibm.com> wrote in message
 news:cgvmca$pfe$1@eclipse.org...
 > Everything is pixel-based.  There is zoom functionality, but it just
 > performs scaling and then rounds to the nearest pixel.
 > Can you be more specific?
 > "Bernd Hofner" <bernd.hofner@gmx.net> wrote in message
 > news:cgvf00$b9o$1@eclipse.org...
 > > Hello,
 > way.
 > > might miss some
 > figures
 > > are getting
 search
 > > help.
 > values.
 > anyone
 > > Thanks in advance!
 > > Bernd
| Re: coordinate system/documentation [message #149255 is a reply to message #149251] | Tue, 31 August 2004 14:07   |  |
| Eclipse User  |  |  |  |  | Originally posted by: none.us.ibm.com
 I can't imagine why you would want different X and Y scale value.  I would
 just take the minimum of the two at startup.
 All you need is a mapping from your model coordinates to a rectangular
 (integer) constraint used in XYLayout.  Depending on that mapping (1mm==1),
 or (0.1mm == 1), you will have more detail as the user zooms into the
 drawing.  We are working with SWT which only supports integers.  You can
 fake what you want by having a zoom level of "100%" really be a zoom level
 10%, so that at 1000% you still have pixel-level accuracy.
 You should be able to use the Scalable[Freeform]RootEditpart to implement
 zoom and XY or FreeformLayout.
 news:ch2dgm$97h$1@eclipse.org...
 > My pleasure :-)
 of
 scrollbars).
 > nice.
 > Probably by calling
 some
 > such),
 that
 to
 CDC)
 > Bernd
 > > > Hello,
 my
 > > way.
 I
 > > > might miss some
 > > figures
 > > > are getting
 > search
 > > > help.
 > > values.
 > > anyone
 > > > Thanks in advance!
 > > > Bernd
| Re: coordinate system/documentation [message #149543 is a reply to message #149255] | Wed, 01 September 2004 08:24   |  |
| Eclipse User  |  |  |  |  | Yes, you're right, a common scale factor for both dimensions is probably better.
 Now, mentioning the constraints, we're getting to the nebulous areas.
 From what I read in the documentation,
 I understood constraints to be positioning hints for the layout manager.
 How does this relate to scaling?
 Now some loud thinking:
 I'm using the ScalableRootEditPart as rooteditpart.
 My topmost EditPart representing my IEdiorInput is called
 DiagramContentsEditPart which extends AbstractGraphicalEditPart.
 DiagramContentsEditPart .createFigure() creates a contentsFigure : Figure
 and sets the XYLayout on this contentsFigure.
 The ScalableRootEditPart can have an associated figure (getFigure()),
 but I don't know which figure that might be. Traversing the JavaDoc hints
 that it might be null.
 Browsing the code reveals it is a viewport. I guess this is the Root Layered
 Pane mentioned
 in the class JavaDoc for ScalableRootEditPart.
 Nevertheless ScalableRootEditPart creates a ZoomManger (getZoomManager()),
 which in turn wants a ScalableFigure for construction.
 Where does that come from? JavaDoc doesn't help here either.
 Code reveals: it is the ScalableLayeredPane (Scalable Layers in above
 mentioned JavaDoc).
 Hmmm. Now I have the following choices:
 a) The ZoomManager provides a method called setUIMultiplyer(double m)
 It seems more of a Divisor, since the JavaDoc states (a bit winded,
 though):
 actualZoom= zoomSetting / m
 b) I could call fig= ScalableRootEditPart.getFigure() which should be an
 instance
 of ScalableFigure (the ScalableLayeredPane) and call fig.setScale().
 That would be a mistake, I guess, since the ZoomManager does just that
 when changing zoom levels.
 So this leaves option a).
 Mission:
 On Zoom Level 100% show the whole picure (as if calling FIT_ALL).
 Note that FIT_ALL corresponds to 8% using my sample data.
 So in DiagramContentsEditPart.refreshVisuals() I added these lines:
 double height= myModel.maxHeight();
 double width= myModel.maxWidth();
 if(getRoot() instanceof ScalableRootEditPart)
 ScalableRootEditPart root= (ScalableRootEditPart)getRoot();
 Dimension available = root.getFigure().getClientArea().getSize();
 // get size of client area
 double zoomScale= 1.0;
 if(width > height)
 zoomScale=  width / (double)available.width;
 else
 zoomScale=  height / (double)available.height;
 // avoid div by zero error
 if(zoomScale == 0.0)
 zoomScale= 1.0;
 root.getZoomManager().setUIMultiplier(zoomScale);
 My, my was I wrong. Reading the setUIMultiplyer() JavaDoc again I see the
 errors of my ways.
 (This just scales the texts displayed in the Zoom Combo...)
 Being able to read is definitly an advantage...
 Furthermore I have the suspicion that the client area has not its final size
 here, yet.
 Nevertheless, option b) seems still a bad idea...
 Please turn me in the right direction!
 Bernd
| Re: coordinate system/documentation [message #149591 is a reply to message #149543] | Wed, 01 September 2004 10:52   |  |
 It doesn't.  The scaling happens only at the time of painting, external to
 the layout.
 Layered
 > Pane mentioned
 > mentioned JavaDoc).
 > though):
 It's a multiplier for the *UI*.  See getZoomAsText, which is displayed in
 the UI.
 So you can have your diagram scaled out to 10%, but tell the user it's at
 100%. (x10)
 > instance
 You should interact only with the ZoomManager.  that is the zoom model.
 > Mission:
 I disagree.  Fit All will be a different zoom level depending on the size of
 the diagram and editor's size.
 >            if(width > height)
 >            else
 >                 zoomScale= 1.0;
 I would pick a constant UI multiplier, probably a power of 2, and then
 calculate the zoom, not the multiplier.
 > errors of my ways.
 size
 > here, yet.
 > Bernd
 You need to intercept at the point when your editor has been sized to its
 final width/height, and the calculate the zoom.
 Is defaulting to FIT_ALL really that important?  You may want to just
 remember the document's previous zoom setting, which is what the Logic
 example does.  And that setting may be FIT_ALL or something else.
| Re: coordinate system/documentation [message #149816 is a reply to message #149739] | Fri, 03 September 2004 05:00  |  |
| Eclipse User  |  |  |  |  | I guess I ran into the old framework trap, looking for a function that one thinks is so common that it should be there, but actually isn't.
 So what I've done now is providing a conversion method int mm2pixel(double
 v).
 For starters, this method converts the given model value ([mm]) to a pixel
 value using the screen resolution (Display.getDPI()).
 Note that the resolution could be different for the x- and y-axis, so I DO
 need diffent "scaling" factors for X/Y!
 I apply this conversion to all layout constraints set during
 refreshVisuals().
 At least now my figures sizes and positions are in sync with the ruler, when
 it is in UNIT_CENTIMETERS mode.
 I guess I can extend that scaling function if I need additional conceptual
 scaling (like 1mm in the drawing corresponds to 100mm in reality,
 to get a large CAD part on a small piece of A4 paper).
 Of course then my ruler is kind of "out of sync" again, because it still
 measures paper sizes and not the "real-world" sizes.
 For now, thanks for your advice!
 CU
 Bernd
 Current Time: Thu Oct 30 21:43:31 EDT 2025
 Powered by FUDForum . Page generated in 0.05867 seconds |
