Home » Archived » BIRT » BIRT 371 report running fine on BIRT Designer but running on taking long time to run(BIRT 371 report running fine on BIRT Designer but running on taking long time to run)
BIRT 371 report running fine on BIRT Designer but running on taking long time to run [message #1496809] Wed, 03 December 2014 04:35 Go to next message
Hi All,
Iam running BIRT 371 report and it is running fine on BIRT Designer but when same report iam running on MAXIMO 7.5.0.4 then it is taking long time to run.
Ex: BIRT Designer taking1 min for more than 5000 records.
MAXIMO taking 45 min for more than 5000 records and some time got blank.
If i restart maximo server then from maximo report took only 1 min .
Any idea??
Re: BIRT 371 report running fine on BIRT Designer but running on taking long time to run [message #1497092 is a reply to message #1496809] Wed, 03 December 2014 09:38 Go to previous messageGo to next message
Moved this to the BIRT forum group.
Re: BIRT 371 report running fine on BIRT Designer but running on taking long time to run [message #1497483 is a reply to message #1497092] Wed, 03 December 2014 16:19 Go to previous messageGo to next message
Not sure, but it sounds like a Maximo problem, not a BIRT problem. Have you asked in the Maximo forums?
Re: BIRT 371 report running fine on BIRT Designer but running on taking long time to run [message #1500311 is a reply to message #1496809] Fri, 05 December 2014 16:49 Go to previous messageGo to next message
If this report runs quickly just after a server restart and is longer after some time, it typically looks like a memory issue: your Maximo server does not have enough memory to handle all app & caches loaded and has to trigger many garbage collectors. Increase "Heap memory" as much as you can depending if the server is 32 bits or 64bits, and set "Permgen memory" to 512 Mb or more. As suggested by Michael Maximo forums probably provide recommendations related to memory setup.
Re: BIRT 371 report running fine on BIRT Designer but running on taking long time to run [message #1502164 is a reply to message #1500311] Sun, 07 December 2014 06:49 Go to previous messageGo to next message
Thank you so much for your reply.
I have already increase heap memory upto 2048. But i dnt know how to increase or set "Permgen memory" to 512 Mb in maximo application .
Re: BIRT 371 report running fine on BIRT Designer but running on taking long time to run [message #1502169 is a reply to message #1502164] Sun, 07 December 2014 06:53 Go to previous message
Can you please send me steps or screen shot for how set set "Permgen memory" to 512 Mb in maximo.
Previous Topic:Cannot open the connection for the driver Oracle DB
Next Topic: Eclipse Birt report not generatimg throw oc4j
Current Time: Sat May 10 04:10:41 EDT 2025
Powered by FUDForum. Page generated in 0.04177 seconds
