Home » Modeling » MDT (Model Development Tools) » Display of an association defined in a profile by an association between two stereotypes (Is it possible to display the line between the two stereotypes objects ? )
Display of an association defined in a profile by an association between two stereotypes [message #1494904] Mon, 01 December 2014 16:29 Go to next message
I create a profile at the root of the profile :
- three stereotypes A, B C extending the metaclass « Class »
- each stereotype has a property
- one association between A and B ;
- one association between B and C
- one stereotype D specialization of C
All the object are in a unique diagram
I can use this profile for a SysML model :
- add stereotype to Class,
- update the property in the tab profile of the tab property
- display the property in a a compartment
- display the association in one of the two Class of the association.
But it is not possible to display the line corresponding to association, between the two classes.
Is there a solution ?
Re: Display of an association defined in a profile by an association between two stereotypes [message #1495440 is a reply to message #1494904] Tue, 02 December 2014 02:58 Go to previous messageGo to next message
I presume this is a Papyrus question, for which you would do much better
to use the Papyrus newsgroup/forum.
Profiles/Stereotypes etc work for me, so I am afraid that without any
model or picture your description means very little to me.
Try asking again on the Papyrus newsgroup with:
1) a model that demonstrates what you are unhappy with
2) a picture showing the deficiency
Ed Willink
On 01/12/2014 21:29, Philippe Revellat wrote:
> I create a profile at the root of the profile : - three stereotypes A, B
> - display the property in a a compartment - display the association in
Re: Display of an association defined in a profile by an association between two stereotypes [message #1496174 is a reply to message #1495440] Tue, 02 December 2014 16:11 Go to previous messageGo to next message
Thank you for your answer.
I will do what you propose.
Ph Revellat
Fwd: Re: Display of an association defined in a profile by an association between two stereotypes [message #1496254 is a reply to message #1496174] Tue, 02 December 2014 17:40 Go to previous message
Where was the model? You waste everyone's time.
See https://wiki.eclipse.org/OCL/ForumNetiquette
Ed Willink
-------- Original Message --------
Subject: Re: Display of an association defined in a profile by an
Date: Tue, 02 Dec 2014 16:11:31 -0500
Reply-To: Philippe Revellat <forums-noreply@xxxxxxxx>
Organization: Eclipse Community Forums
Newsgroups: eclipse.modeling.mdt
References: <m5jrf9$dgv$1@xxxxxxxxe.org>
Ph Revellat
Previous Topic:MDT BPMN2 Git repository has been renamed
Next Topic:convert BPMN20 OMG CMOF metamodel to ecore
Current Time: Sat Jul 19 04:43:16 EDT 2025
Powered by FUDForum. Page generated in 0.03698 seconds
