Home » Eclipse Projects » Remote Application Platform (RAP) » Generating test id for components not created programmatically(During testing RAP 2.3 with Selenium it came into the place where I should generate test-ids for menu elements)
Generating test id for components not created programmatically [message #1494478] Mon, 01 December 2014 09:03 Go to next message
Could you give me any hint how I could generate test-ids for menu elements in RAP? The menu elements are defined in plugin.xml and for this reason the test-id assignment described at http://eclipsesource.com/blogs/2014/04/29/how-to-write-ui-tests-for-rap-with-selenium-2-0/ don't work for them. Any ideas are welcome.
Re: Generating test id for components not created programmatically [message #1494503 is a reply to message #1494478] Mon, 01 December 2014 09:30 Go to previous messageGo to next message
if you are using RAP 2.3 you could try this approach [1]. Please note
that PhaseListeners are already removed in RAP 3.0 (were deprecated in
RAP 2.3). We are looking for replacement.
[1] https://gist.github.com/ralfstx/5791804
HTH,
Ivan
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Generating test id for components not created programmatically [message #1494574 is a reply to message #1494503] Mon, 01 December 2014 10:36 Go to previous messageGo to next message
I managed to get a point where I can attach my custom HTML attribute. I attach an IWindowListener inside our WorkbenchAdvisor.postStartup method. Then I use something like this:
public void windowOpened(IWorkbenchWindow window) {
	if ( window instanceof ApplicationWindow ) {
		ApplicationWindow applicationWindow = (ApplicationWindow) window;
		MenuManager menuManager = applicationWindow.getMenuBarManager();
		for (IContributionItem item : menuManager.getItems()) {
			if (item instanceof MenuManager) {
				defineTestIdsForMenuManager((MenuManager) item);
public void defineTestIdsForMenuManager( MenuManager item ) {
	if ( item.getMenu() != null ) {
		System.out.println( "Menu with id " + item.getId() + " gets id " + WidgetUtil.getId(item.getMenu()) );
		UITestUtil.setTestId(item.getMenu(), item.getId());
	for (IContributionItem child : item.getItems() ) {
		if ( child instanceof MenuManager ) {
			defineTestIdsForMenuManager((MenuManager) child);
The problem is that the HTML attribute does not show up in the HTML element. Any idea why?
[Updated on: Mon, 01 December 2014 10:37] by Moderator
Re: Generating test id for components not created programmatically [message #1494619 is a reply to message #1494574] Mon, 01 December 2014 11:16 Go to previous message
Got it. So works:
UITestUtil.setTestId(menuManager.getMenu().getParentItem(), menuManager.getId());
So the attribute must be added to the menu.getParentItem().
Works, great.
Previous Topic:Change Label Image when pressed
Next Topic:[Combo] Text Highlighting after SelectionChange by a Function
Current Time: Sun Jul 20 22:12:37 EDT 2025
Powered by FUDForum. Page generated in 0.03729 seconds
