Home » Archived » BIRT » preview as pdf
preview as pdf [message #149277] Wed, 29 March 2006 10:05 Go to next message
Originally posted by: hans.gruber.wuerth-phoenix.com
when i create a report with report designer in eclipse, and i select from
file menu -preview as pdf- the only message i get is Error happened while
running the report
is this a known issue or i'm doing something wrong? I'm using birt version
2_0_1
thanx Hans
Re: preview as pdf [message #149291 is a reply to message #149277] Wed, 29 March 2006 07:58 Go to previous messageGo to next message
This should work. Did you copy the iText jar to the PDF emitter plugin?
http://www.eclipse.org/birt/phoenix/build/#itext
Jason
"Hans Gruber" <hans.gruber@wuerth-phoenix.com> wrote in message
news:e0e7n2$ei0$1@utils.eclipse.org...
> running the report
> 2_0_1
> thanx Hans
Re: preview as pdf [message #149381 is a reply to message #149291] Thu, 30 March 2006 04:26 Go to previous messageGo to next message
thanks jason,
now i found the real problem: how can i configure that eclipse uses my local
tomcat installation? In Window/Preferences/BIRT/Preview Server i can set
localhost and as port 8080 (my local tomcat) but it doesn't work.
is there anything else i have to do?
Hans
"Jason Weathersby" <jweathersby@actuate.com> wrote in message
news:e0eaqc$a84$1@utils.eclipse.org...
> Jason
> > Hi,
from
while
> > running the report
version
> > 2_0_1
> > thanx Hans
Re: preview as pdf [message #149581 is a reply to message #149381] Thu, 30 March 2006 07:59 Go to previous messageGo to next message
I dont think that is currently possible. The prefernces are still for the
internal Tomcat plugin.
You can download the Report Engine download which contains a Birt Web Viewer
to deploy to your
Tomcat.
Jason
news:e0g88b$qvd$1@utils.eclipse.org...
> thanks jason,
> local
> Hans
>> Jason
>> > Hi,
> from
> while
>> > running the report
> version
>> > 2_0_1
>> > thanx Hans
Re: preview as pdf [message #149890 is a reply to message #149581] Fri, 31 March 2006 04:24 Go to previous message
thanx, i use the internal plugin now, and it works with copying the jar in
the right directory!
Hans
news:e0gv8p$ioc$1@utils.eclipse.org...
Viewer
> to deploy to your
> Tomcat.
> Jason
> > thanks jason,
> > local
> > Hans
plugin?
> >> Jason
> >> > Hi,
> > from
> > while
> >> > running the report
> > version
> >> > 2_0_1
> >> > thanx Hans
Previous Topic:Dynamic Imageing from Stream
Next Topic:to the friends of cocoon
Current Time: Sun Jul 27 22:25:29 EDT 2025
Powered by FUDForum. Page generated in 0.10875 seconds
