Home » Archived » BIRT » pass parameter from html to pdf
pass parameter from html to pdf [message #149192] Wed, 29 March 2006 03:01 Go to next message
Originally posted by: almasalki.hotmail.com
hi for all
I build the parametrized report and I browse it by using web
viewer(frameset format) and i add link to this report to allow the user to
display the report as pdf.
now because the report is parametrized,how can I get the values from the
parameter pop-up that are used to run the html report into a URL string
for generating a PDF(by click on the link).
thanks in advance
Re: pass parameter from html to pdf [message #149308 is a reply to message #149192] Wed, 29 March 2006 12:22 Go to previous messageGo to next message
I made a change to the Web Viewer which allows that. Download the zip
attached to the bug report and update your files. This allows you to:
Generate the report using /run? both in PDF and HTML (but printable form)
https://bugs.eclipse.org/bugs/attachment.cgi?id=37148
Abo Alnnor wrote:
> hi for all
> thanks in advance
Re: pass parameter from html to pdf [message #149369 is a reply to message #149308] Thu, 30 March 2006 04:06 Go to previous messageGo to next message
when I replace these jsp files,the use frameset format to run the
parametrized report, I have alot of exceptions in generate Servlet
can you help me
and I hope, you understood my first question correctly,so let me explain
I design the report and put hyperlink in the bottom of it which allow me
to call the other address to generate the pdf format, now when I run the
report by using (frameset format) and use the pop-up window to enter the
paraemters and regenerate the report, I want to pass these parameters on
the link to generate the report as pdf format on my new parameter.
Re: pass parameter from html to pdf [message #150127 is a reply to message #149369] Sat, 01 April 2006 12:14 Go to previous messageGo to next message
I don't know about the link at the bottom of your report. There is another
implementation on this newsgroup in earlier threads. Check it out, it
might solve it.
Re: pass parameter from html to pdf [message #150503 is a reply to message #150127] Mon, 03 April 2006 23:51 Go to previous messageGo to next message
> might solve it.
Hi Abo
I have implemented the same n its working for me.
Find the jsp code below:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Frameset//EN"
"http://www.w3.org/TR/html4/frameset.dtd">
<HTML>
<HEAD>
<TITLE>BIRT Reports in JSP</TITLE>
</HEAD>
<FRAMESET cols="20%, 80%">
<FRAMESET rows="100, 200">
<FRAME src="Frame1.html">
</FRAMESET>
<FRAME
src=" run?__report=F:/eclipse/workspace/BIRT/etc/BIRT_Equity_Secto rs.rptdesign&AccountID=299&__format=html ">
</FRAMESET>
</HTML>
Praful
Re: pass parameter from html to pdf [message #150511 is a reply to message #149369] Mon, 03 April 2006 23:53 Go to previous message
Hi Abo
I tried the same, n it works for me
Following is the JSP code
<HTML>
<HEAD>
</HEAD>
</FRAMESET>
<FRAME
</FRAMESET>
</HTML>
Praful
Previous Topic:Birt Chart Serializer and EMF
Next Topic:BIRT - extremly slow PDF rendering
Current Time: Wed Sep 24 15:42:21 EDT 2025
Powered by FUDForum. Page generated in 0.05501 seconds
