Home » Newcomers » Newcomers » Getting started
Getting started [message #149157] Tue, 18 April 2006 11:05 Go to next message
Originally posted by: garyamato.msn.com
I am new to Eclipse. I just downloaded the files, unzipped them and tried
to run the Eclipse.exe. I got a message that it could not access the
jarfile startup.jar. What do I do now?
Gary
Re: Getting started [message #149171 is a reply to message #149157] Tue, 18 April 2006 11:36 Go to previous messageGo to next message
Originally posted by: hendrik_maryns.despammed.com
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
> tried to run the Eclipse.exe. I got a message that it could not access
> the jarfile startup.jar. What do I do now?
Did you run eclipse.exe in the folder you unzipped it to? No link?
H.
Hendrik Maryns
www.lieverleven.be
http://aouw.org
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.2 (GNU/Linux)
iD8DBQFERQdqe+7xMGD3itQRAmPfAJoCIK2RYlEfs7vB+9Gk5mGFaLLbwQCe LWV8
DBrB6oVwnaAmFqqh2JOKQkw=
=d8TF
-----END PGP SIGNATURE-----
Re: Getting started [message #149178 is a reply to message #149171] Tue, 18 April 2006 11:59 Go to previous messageGo to next message
I put the unzipped files in a "received" folder and then extracted
eclipse.exe, but nothing else, to a separate folder called "eclipse."
Both of these are under "my documents." Is this wrong?
Re: Getting started [message #149184 is a reply to message #149178] Tue, 18 April 2006 12:09 Go to previous messageGo to next message
OK, I got it to work. I just moved the entire zipped file to a new
eclipse file under my programs, extracted everythng to that file and ran
the eclipse.exe. thanks for your help.
Re: Getting started [message #149190 is a reply to message #149178] Tue, 18 April 2006 12:13 Go to previous message
Hash: SHA1
Yes. You should unzip the entire folder. startup.jar is also in there.
I suggest you unzip it to a folder eclipse under Program Files.
H.
Hendrik Maryns
www.lieverleven.be
http://aouw.org
iD8DBQFERRAxe+7xMGD3itQRAnROAJ4s+R5x9WuuMF3VIMIqAsB49+qCOACf VKV6
i+UMMUffNN3icHL8//CI9kE=
=zEB6
Previous Topic:Data Source Definition Problem
Next Topic:The currently displayed page contains invalid values Eclipse v3.1.1
Current Time: Wed Nov 05 02:46:19 EST 2025
Powered by FUDForum. Page generated in 0.10317 seconds
