Home » Newcomers » Newcomers » Error message while launching eclipse(Error message while launching eclipse)
Error message while launching eclipse [message #1489675] Thu, 27 November 2014 10:32 Go to next message
I am getting the following error message while launching eclipse on windows professional 64 bit. The error message reads as follows "Java was started but returned exit code=13". For the complete error message I have attached a screenshot image which can be of reference. I tried searching for a fix on the google but did not find any relevant once resolved on windows operating system.
  • Attachment: eclipse.png
    (Size: 35.22KB, Downloaded 587 times)
Re: Error message while launching eclipse [message #1490182 is a reply to message #1489675] Thu, 27 November 2014 20:23 Go to previous messageGo to next message
Could it be you're trying to run a 64-bit Eclipse on a 32-bit JRE
Re: Error message while launching eclipse [message #1490391 is a reply to message #1490182] Fri, 28 November 2014 00:33 Go to previous messageGo to next message
I have downloaded the 64 bit from here www.oracle.com/technetwork/java/javase/downloads/java-se-jre-7-download-432155.html and installed the same but I still see the same error message.
Re: Error message while launching eclipse [message #1490898 is a reply to message #1490182] Fri, 28 November 2014 09:42 Go to previous messageGo to next message
I recently installed an updated version of the jre for my chrome browser will that cause an issue. If yes, kindly let me know how to role it back to the previous version or access eclipse with the the earlier version. This command mentioned in here did not work for me. command: eclipse.exe -vm c:\path\to\64\bit\bin\javaw.exe. www.stackoverflow.com/questions/20763583/java-was-started-but-returned-exit-code-13-eclipse.
Re: Error message while launching eclipse [message #1491000 is a reply to message #1490898] Fri, 28 November 2014 11:25 Go to previous messageGo to next message
The best things I can tell you are these:
1) Follow the sticky post from the top of this forum:
https://www.eclipse.org/forums/index.php/t/198527/
2) If you plan Java development, you need a JDK rather than a JRE. I
advise you to download, expand, but not install a JDK, the latest 7 or 8
as you wish, and keep it separate from the one your computer is running on.
This makes it so that you won't ever need to ask the question you've
just asked in this post.
I would also
a) put this "private" JDK on a path like /home/russ/dev/jdk1.7.0_71
(C:\Users\Nandan\dev\jdk1.7.0_71)
b) run Eclipse off it (instead of the one your computer uses)
c) tell Eclipse about it using the -vm option in eclipse.ini (see
http://wiki.eclipse.org/Eclipse.ini)
This will ensure that your computer can receive updates to its JRE
without affecting your Eclipse development.
Re: Error message while launching eclipse [message #1494424 is a reply to message #1491000] Mon, 01 December 2014 08:09 Go to previous message
Thank you that helped.
Previous Topic:Howto Open the Run Configuration Window
Next Topic:Which eclipse archive version is right for me?
Current Time: Sat Jul 26 21:40:27 EDT 2025
Powered by FUDForum. Page generated in 0.27114 seconds
