Home » Modeling » Papyrus » Complex C++ Types(C/CPP profile stereotypes usage)
Complex C++ Types [message #1489939] Thu, 27 November 2014 15:31 Go to next message
How would I define some more complex C++ types using the C/CPP profile stereotypes?
It's fairly easy for simple things (e.g., pointer), but how can I define, either as class property or as a function parameter, for example
A constant pointer to a constant integer : "int const * const"
A constant pointer to a pointer to an int: "int * * const"
I can only apply each stereotype once to a property/parameter...
I could cheat for properties, e.g., by declaring multiple properties that build on each other - although that is messy. But I can' cheat like that for parameters...
Thanks in advance!
Re: Complex C++ Types [message #1490822 is a reply to message #1489939] Fri, 28 November 2014 08:23 Go to previous messageGo to next message
The Ptr stereotype of the C++ profile has an attribute called "declaration". If undefined, it simply corresponds to a star. But you can write "**" in this attribute to obtain a double pointer (and then combine that with the Const stereotype).
You can also write "* const" in the definition part, in this case the result is "const int* const" which is not exactly the same as you wrote (not sure about C++ semantic subtleties in this context).
Re: Complex C++ Types [message #1490835 is a reply to message #1490822] Fri, 28 November 2014 08:33 Go to previous messageGo to next message
I update the Papyrus wiki page accordingly: C++ profile wiki
Re: Complex C++ Types [message #1490866 is a reply to message #1490835] Fri, 28 November 2014 09:08 Go to previous message
Thanks Ansgar, that's what I needed!
And thank you for updating the wiki page.
BTW, did you know about the "clockwise spiral" method of evaluating C++ declarations?
Using that method, you'll see that "const int* const" is a "constant pointer to an int constant", which is equivalent to what I had in my initial question.
Previous Topic:Wait time actions in Papyrus
Next Topic:Customize a Papyrus Nattable
Current Time: Sun Jul 27 02:28:00 EDT 2025
Powered by FUDForum. Page generated in 0.06210 seconds
