EMFStore and Edapt [message #1489755] |
Thu, 27 November 2014 11:59  |
Does EMFStore currently have any integration with Edapt?
It would be useful (although maybe difficult) if changes to a model structure (.ecore model) could be recorded/versioned as well as changes to a model instance as this would give good version history of an evolving model structure AND content. Just wondering if anyone had any ideas in this area.
Neil
Re: EMFStore and Edapt [message #1496215 is a reply to message #1491877] |
Tue, 02 December 2014 16:57   |
Neil,
no, there will be no information on the migration in the history view
since they are not actual changes in the data. Consider a rename of an
attribute in your model, it will not change instance data values really,
just the name of the attribute which is metadata from this point of
view. But maybe I do not get your question correctly?
Maximilian
Am 29.11.2014 11:10, schrieb Neil Mackenzie:
> I don't have much time at the moment but I might be able to get an
> hour or 2 a week to look into this.
> When a model is migrated I assume some information would be available
> in the EMFStore history view.
> Do you know what level of detail would/should be recorded e.g:
> 1.) just one entry for the whole migration e.g. 'migrated library
> package using migration definition x'
> 2.) one entry for each migration operation e.g. 'applied 'rename field
> (author to writer) and extract to superclass (field NumOfPages) in
> library package'
> 3.) one entry for each instance affected e.g. 'renamed field author in
> book1 , renamed field author in book 2,renamed field author in book 3'
> Neil
Maximilian Kögel
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
FUDForum. Page generated in 0.04499 seconds
