Home » Modeling » EMF » import an xmi file into EMF
import an xmi file into EMF [message #1487156] Tue, 25 November 2014 11:08 Go to next message
I'm a beginner in EMF , i have done an extension of CWM by Entreprise architect and i generated the xmi file ,my question is how can i import that xmi file into EMF and create an ecore model from that and genered it ?
Any help on how this can be done? Sad
Re: import an xmi file into EMF [message #1487858 is a reply to message #1487156] Wed, 26 November 2014 00:47 Go to previous messageGo to next message
lami,
Comments below.
On 25/11/2014 8:49 PM, lami P wrote:
> Hello,
Container Warehouse Model?
I'm not sure what such an extension is? This is an extension of CWM's
Ecore model? What exactly is such a thing?
It sounds like you want to do an "Extended CWM" -> Ecore conversion.
EMF doesn't provide that. I don't even know what an extension to CWM
would look like, other than that it's a model you've represented as XMI.
> Any help on how this can be done? :( Thanks
Re: import an xmi file into EMF [message #1488136 is a reply to message #1487156] Wed, 26 November 2014 05:41 Go to previous messageGo to next message
It depends what YIOU mean by an ecore model.
If you have a valid *.xmi file the Sample Reflective Ecore Editor will
load it, so you have nothing to do.
I'm guessing that CWM might be a profile extension of UML, so in so far
as you can find a UML compatibility between Eclipse UML2 and EA, it
might load in Eclipse UML2 or Papyrus. Search the UML newsgroup for
discussions on EA compatibility. NV=B Eclipse UML2 supports UML 2.2,
2.4, 2.5. EA seems to be UML 2.3.
Once you can load into Eclipse UML2 you can use UML2Ecore to convert to
an Ecore metamodel.
With nothing to look at, it's hard to comment further.
Ed Willink
On 25/11/2014 19:49, lami P wrote:
> Hello,
> it ?
Re: import an xmi file into EMF [message #1489960 is a reply to message #1488136] Thu, 27 November 2014 15:56 Go to previous message
my biggest question is how can i transform a CWM specification to an Ecore EMF ? i have done an extension of the CWM metamodel in Entreprise architect and i have also it rose .mdl , is there any way to import the CWM into EMF?
Thanks for help
Previous Topic:[Xcore]
Next Topic:XMI Resource & "OutOfMemoryError: GC Overhead limit exceeded"
Current Time: Sat Jul 26 00:39:11 EDT 2025
Powered by FUDForum. Page generated in 0.03837 seconds
