Home » Language IDEs » Java Development Tools (JDT) » Strange watch variables behavior
Strange watch variables behavior [message #148443] Fri, 12 March 2004 19:57 Go to next message
I've just started using Eclipse, and so far I really like it, but I
have one major problem I can't seem to fix. I finally tracked the
problem down so its repeatable, but its very strange. Do the
following:
Create a new project and a package called foo. Now create a class
called foo in that package like this:
package foo;
public class foo
int var;
public foo(int x)
var = x;
public void print()
System.out.println("HI");
Now create a file in the default package with a class main in
Main.java:
import foo.*;
public class Main {
public static void main(String[] args)
//this is as simple as they come
int i, j;
i = 10;
j = 20;
i = 3*j;
foo x = new foo(7);
System.out.println("i : " + Integer.toString(i));
OK. Now start debugging the app and put a breakpoint on the j=20
line. When you get there find the value of i in the variables window
and choose "watch" from the context menu. As expected it shows up in
the expressions window. Now step through the code. The value of i
is correctly updated in the expressions window until you execute the
foo x = new foo(7); line. At that point the value of i in the
expressions window is displayed as "<error(s) during the
evaluation>".
From this point on (I have other code that does a lot more than this)
its impossible to put a watch on ANY variable in ANY method!! What's
up with that?? If I rename the class in the package from foo to bar
it doesn't matter. All that matters is that I've accessed something
from that package! Am I doing something wrong or is this a bug?
Re: Strange watch variables behavior [message #148459 is a reply to message #148443] Sat, 13 March 2004 04:51 Go to previous messageGo to next message
seems like a bug to me.
dit you file a bug report?
johan
> following:
> package foo;
> public class foo
> int var;
> public foo(int x)
> var = x;
> public void print()
> Main.java:
> import foo.*;
> public class Main {
> int i, j;
> i = 10;
> j = 20;
> i = 3*j;
> foo x = new foo(7);
> evaluation>".
Re: Strange watch variables behavior [message #148491 is a reply to message #148459] Sat, 13 March 2004 10:25 Go to previous messageGo to next message
No. I did look in the bug database and I didn't see it. Since it
seems so big I figured if it really was a bug somebody else would
have seen it by now, so I figured I was doing something wrong.
> johan
>> following:
>> package foo;
>> public class foo
>> int var;
>> public foo(int x)
>> var = x;
>> public void print()
>> Main.java:
>> import foo.*;
>> public class Main {
>> int i, j;
>> i = 10;
>> j = 20;
>> i = 3*j;
>> foo x = new foo(7);
>> window
>> in
>> the
>> evaluation>".
>> this) its impossible to put a watch on ANY variable in ANY method!!
>> What's
>> bar
>> something
Re: Strange watch variables behavior [message #148835 is a reply to message #148491] Tue, 16 March 2004 05:55 Go to previous messageGo to next message
I assume you now filed the bug ;-)
Dani
>>johan
>>>following:
>>>package foo;
>>>public class foo
>>> int var;
>>> public foo(int x)
>>> var = x;
>>> public void print()
>>>Main.java:
>>>import foo.*;
>>>public class Main {
>>> int i, j;
>>> i = 10;
>>> j = 20;
>>> i = 3*j;
>>> foo x = new foo(7);
>>>window
>>>in
>>>the
>>>evaluation>".
>>>What's
>>>bar
>>>something
Re: Strange watch variables behavior [message #148967 is a reply to message #148835] Wed, 17 March 2004 08:32 Go to previous message
yes. Thanks to all for their help.
Previous Topic:Strange behavior when Ctrl-Left Click on symbol
Next Topic:Ant tasks and types have leading / in M7
Current Time: Sat Oct 18 19:14:15 EDT 2025
Powered by FUDForum. Page generated in 0.04444 seconds
