Home » Eclipse Projects » Remote Application Platform (RAP) » rap-client.js & webapp startup speed
rap-client.js & webapp startup speed [message #1488807] Wed, 26 November 2014 18:17 Go to next message
I found that rap-client.js, which is seemingly built at runtime from a number of shorter js files sitting in org.eclipse.rap.rwt-3.0.0-M3.jar, has the size of 2.04 MB, containing non-minified javascript with whitespace, comments, what not.
Though late releases of RWT have significantly decreased the webapp startup delay in the browser (the gray gradient before the main form appears), seems had rap-client.js been minified, the startup time would have shortened even further.
If I remember correctly, at some point around M2.0 the original js minification was dropped to save resources, but would it be possible to drop the process of runtime assembly of rap-client.js from pieces, and have that guy jar'ed as already assembled and minified?
Thanks in advance,
Sergei
Re: rap-client.js & webapp startup speed [message #1489564 is a reply to message #1488807] Thu, 27 November 2014 08:31 Go to previous messageGo to next message
Hi Sergei,
are you running your application in "development mode"? rap-client.js
will not be minified in development mode, only in production.
Best,
Ivan
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: rap-client.js & webapp startup speed [message #1489569 is a reply to message #1488807] Thu, 27 November 2014 08:38 Go to previous messageGo to next message
Hi Sergei,
As Ivan said, in production mode, RAP uses a concatenated and minified
client.js. This file is not created at runtime, it's included in the jar
already.
In development mode, you get the plain JS to enable debugging.
Ralf
Ralf Sternberg
Re: rap-client.js & webapp startup speed [message #1489658 is a reply to message #1489564] Thu, 27 November 2014 10:14 Go to previous messageGo to next message
Many thanks, Ivan and Ralf,
you are right, that was the development mode. Though as I run it in the production mode (the tick-box "RAP settings/Start in development mode" in the RWT Application launch config UI unchecked), I can see rap-client.js only partly minified.
As Ralf mentioned, the minified version (client.js) is in the jar, but then a non-minified tail is appended to that when rap-client.js is created (in my Eclipse workspace its location is /.metadata/.plugins/org.eclipse.rap.tools.launch.rwt/launch_config_name/web-app/rwt-resources/).
Probably not a big deal as that tail adds up only 10% to the file, but still a 1MB javascript looks big having mobile browsers/poor connections in mind. I suspect only part of it is needed in most webapps using only a small subset of the widgets, but even the Hello world has to pay the startup time price downloading a 1MB file at every screen refresh (EDIT: when a new UI session is created).
People using Bootstrap and other HTML5 frameworks often select (manually) which components' javascript to include in the pursuit of decreasing the js load time.
The server part of RWT could auto-assemble the client js from fragments only for the widgets being used by a given webapp, and then minify that file. In that case the javascript would be the minimal possible size, and the initial delay would only be experienced by the very first session, and all consecutive sessions would receive the size-optimized client.js.
Thanks for the fantastic framework!
Sergei
[Updated on: Thu, 27 November 2014 14:21] by Moderator
Re: rap-client.js & webapp startup speed [message #1489723 is a reply to message #1489658] Thu, 27 November 2014 11:23 Go to previous messageGo to next message
Hi Sergei,
the additional uncompressed javascript comes from appearances js files
and Forms widgets, but as you mentioned, the overhead is not so big. We
are working hard to keep the client.js as small as possible. See related
bugzillas:
401126: [Forms] Register and load JavaScript on demand in forms bundle
https://bugs.eclipse.org/bugs/show_bug.cgi?id=401126
393497: Compress JavaScript in Forms bundle
https://bugs.eclipse.org/bugs/show_bug.cgi?id=393497
363745: Register appearances as static JavaScript
https://bugs.eclipse.org/bugs/show_bug.cgi?id=363745
Best,
Ivan
Ivan Furnadjiev
Re: rap-client.js & webapp startup speed [message #1489728 is a reply to message #1489658] Thu, 27 November 2014 11:27 Go to previous message
BTW... the rap-client.js is not downloaded on every browser refresh
because browser caches it.
Ivan Furnadjiev
Previous Topic:Timing of 3.0 release
Next Topic:[ANN] RAP 3.0 release plan changed
Current Time: Fri Jul 25 23:37:29 EDT 2025
Powered by FUDForum. Page generated in 0.26287 seconds
