Re: Set Version of Plugins Generated from Ecore [message #1489406 is a reply to message #1485388] |
Thu, 27 November 2014 05:36  |
what is your main motivation of not sharing those bundles? Even if they
are completely generated, it does not do any harm in experience. In any
case, I would at least share the bundle itself. Besides the version,
there might be other things you want to adapt, e.g. the package
visibility. If you do not want to share the bundle, I think you need to
adapt the code generator.
Best regards
Jonas
Am 24.11.2014 08:41, schrieb Timo Rohrberg:
> Hello everybody,
> based on an Ecore model living in its own "Generic Project", I am
> generating the complete Model, Edit, and Editor plugins via the Eclipse
> IDE (and later via Tycho within an automated build environment). Those
> plugins are not shared via GIT since they are completely generated.
> Unfortunately, all the plugins get the version 1.0.0.qualifier. Is there
> any way to set the desired version which is written to the MANIFEST.MF
> file within the Ecore model or the generator model? I would like to
> avoid sharing those projects in the SCM just for maintaining the
> plugins' versions.
> I appreciate any hint. Thank you very much.
> Timo
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
FUDForum. Page generated in 0.03846 seconds
