Home » Modeling » GMF (Graphical Modeling Framework) » Re: How to add a new tab to the Properties view in a GMF editor
Re: How to add a new tab to the Properties view in a GMF editor [message #147468] |
Wed, 22 August 2007 09:54  |
Satyajit,
This is best asked on the GMF newsgroup, which I've added to the "to"
list of the reply, so you can continue to use this thread.
Satyajit Chakraborty wrote:
> Hi all,
> I have created a GMF editor which is based on a ecore model. The editor is working quite well, but now I want to add a new tab to the Properties view. I have some custom properties which are not a part of my original domain model and I would like to show them in different property tabs. If I select a shape on the diagram, these extra tabs should show up. I am using GMF 1.0.3.
> Please help.
> Regards,
> Satyajit.
Re: How to add a new tab to the Properties view in a GMF editor [message #147546 is a reply to message #147468] |
Wed, 22 August 2007 22:39   |
Satyajit,
For GMF 1.0.3, I have successfully added a custom tab to the Properties
view in the following way. I don't know this is a smart way, though.
1. Add a PropertyTabs extension
<extension point="org.eclipse.ui.views.properties.tabbed.propertyTabs" >
<propertyTabs
contributorId="org.eclipse.gmf.runtime.diagram.ui.properties ">
<propertyTab
category="Advanced"
id="property.tab.YourAdvancedPropertySection"
label="YourCustomLabel"/>
</propertyTabs>
</extension>
2. Add a PropertySection
<extension point="org.eclipse.ui.views.properties.tabbed.propertySections ">
<propertySections
<propertySection
class="org.example.YourPropertySection"
filter="org.example.YourEditPartPropertySectionFilter"
id="property.section.YourAdvancedPropertySection"
tab="property.tab.YourAdvancedPropertySection"/>
</propertySections>
</extension>
3. Create YourPropertySection class by extending AbstractPropertySection
4. Create YourEditPartPropertySectionFilter class implementing IFilter
public class YourEditPartPropertySectionFilter implements IFilter {
public boolean select(Object toTest) {
if (toTest instanceof YourEditPart) {
return true;
return false;
I hope this helps you.
Koji
Ed Merks wrote:
> Satyajit,
>> Hi all,
>> Please help.
>> Regards,
>> Satyajit.
Re: How to add a new tab to the Properties view in a GMF editor [message #148857 is a reply to message #148841] |
Tue, 04 September 2007 08:15   |
Hi Begoña,
No, your PropertySection doesn't need to implement IPropertySource.
Executing a command is the regular way to edit both your semantic model and notation model.
Are you using the editingDomain you can get from your AttributeInstanceEditPart when executing the SetCommand?
If not, you should.
When a node corresponding to your AttributeInstanceEditPart is selected, your PropertySection.setInput() is called with ISelection from which you can get the AttributeInstanceEditPart instance. Then you can get the editingDomain by AttributeInstanceEditPart.getEditingDomain().
Koji
Subject: Re: How to add a new tab to the Properties view in a GMF editor
Date: Tue, 4 Sep 2007 10:44:46 +0200
> Hi Koji,
> is it also necessary to implement a IPropertySource if you want that both
> the diagram and the model change when the new PropertySection is modifyed?
> or is it enought to implement the changes of the model by executing a
> Command?. I have tried the second approach but I am able to change the model
> but the diagram is not refreshed.
> Do you have any idea?
> Thanks in advance!!
> "Koji Hashimoto" <kojihashi@gmail.com> escribió en el mensaje
> news:1ca0bced7b9d5b14c629907a5b3d4c6c$1@www.eclipse.org...
> > Satyajit,
> > view in the following way. I don't know this is a smart way, though..
> > <propertyTabs
> > <propertyTab
> > category="Advanced"
> > </propertyTabs>
> > </extension>
> > <extension
> > <propertySections
> > <propertySection
> > </propertySections>
> > </extension>
> > return true;
> > return false;
> > Koji
> > Ed Merks wrote:
> >> Satyajit,
> >>> Hi all,
> >>> editor
> > using GMF 1.0.3.
> >>> Please help.
> >>> Regards,
> >>> Satyajit.
Re: How to add a new tab to the Properties view in a GMF editor [message #148896 is a reply to message #148880] |
Tue, 04 September 2007 12:44   |
Hi Begoña, I send you a simple code you can add to your XPropertySection
file that implements your property section.
This is a handler that is executed when a text field is modified. Replace
projectName and projectPackage to your own ones:
protected void handleNameModified()
Element e = (Element) getGMFElement();
String newName = textName.getText();
EAttribute atr =
projectName.projectPackage.eINSTANCE.getElement_NameElement( );
doSetCommand(e, atr, newName);
The method getGMFElement brings to you the EMF element that represents the
selected node from your diagram. Replace 'Element' to your own one:
protected Element getGMFElement()
StructuredSelection ss = (StructuredSelection) getSelection();
if(ss != null)
Element e = (Element) ss.getFirstElement();
return e;
else
return null;
And the method doSetCommand executes the transaction that changes the
value of the attribute Name, in this case:
public void doSetCommand(Object owner, Object feature, Object value)
EditingDomain editingDomain = ((projectDiagramEditor)
getPart()).getEditingDomain();
SetCommand sCommand = (SetCommand) SetCommand.create(editingDomain,
owner, feature , value);
editingDomain.getCommandStack().execute(sCommand);
Try to adapt this code to your project and see if it works.
Salut!
Marc.
Re: How to add a new tab to the Properties view in a GMF editor [message #148937 is a reply to message #148880] |
Wed, 05 September 2007 00:21   |
Begoña,
I think I understand your real problem.
The notification is issued by not AttributeInstance but Value, right?
Then, you might have to override handleNotificationEvent() in
AttributeInstance EditPart as follows:
protected void handleNotificationEvent(Notification notification) {
if (notification.getNotifier() instanceof Value) {
// refresh your node
super.handleNotificationEvent(notification);
I'm not sure this solution is correct. I'm inspired by the following
article:
http://wiki.eclipse.org/GMF_Tips#Making_figures_sensitive_to _attributes_of_semantic_elements
Give it a try!
Koji
Begoña Moros wrote:
> Hi Koji,
> Thank you for your answer. I do exactly what you have explained!!, the
> problem is that the SetCommand modify the 'value' object that is referenced
> from the AttributeInstance (that is,
> attributeInstance.getValue().setValue(aValue)) So, when the value is changed
> in the PropertySection the notification never arrives to
> AttributeInstanceEditPart to refresh. I guess the notification is sent to
> the ValueEditPart that it does not exist.
> I hope I explain myself clear enough. Any idea about where the problem is?
> Best regards,
> Begoña
> news:20070904.211549.193696205.kojihashi@gmail.com...
> Hi Begoña,
> notation model.
> If not, you should.
> Koji
> From: "Begoña Moros" <bmoros@um.es>
>> Hi Koji,
>> model
>> Thanks in advance!!
>> > Satyajit,
>> > <propertyTabs
>> > <propertyTab
>> > category="Advanced"
>> > </propertyTabs>
>> > </extension>
>> > <extension
>> > <propertySections
>> > <propertySection
>> > </propertySections>
>> > </extension>
>> > return true;
>> > return false;
>> > Koji
>> > Ed Merks wrote:
>> >> Satyajit,
>> >>> Hi all,
>> >>> editor
>> > If
>> > using GMF 1.0.3.
>> >>> Please help.
>> >>> Regards,
>> >>> Satyajit.
Re: Adding Property Tabs for all GMF Editors [message #482015 is a reply to message #481866] |
Tue, 25 August 2009 03:11  |
Originally posted by: msp.informatik.uni-kiel.de
I just realized, if I change the getContributorId() method of the
editor's diagram editor part to return
org.eclipse.gmf.runtime.diagram.ui.properties, then my new tab does show
up when using this string as contributor. However, this does not solve
my problem, as I don't want to change the editors.
Miro
Miro Spoenemann wrote:
> Hello,
> I would like to add a property tab and a section for all GMF generated
> editors. However, I'm not sure whether this is possible.
> I was able to add a tab and a section for a specific GMF editor by using
> the propertyTabs and propertySections extension points and setting the
> same property sheet page contributor ID as it is defined for the
> generated property tabs in the editor's diagram plugin. This identifier
> simply equals the diagram plugin ID.
> To extend this approach to all GMF editors, I tried using
> org.eclipse.gmf.runtime.diagram.ui.properties as contributor ID as is is
> suggested in the post below. However, the tab does not show up in this way.
> The article "The Eclipse Tabbed Properties View" at Eclipse Corner
> states the following:
> "A workbench part cannot make use of two or more property contributors.
> It can identify a single property contributor by implementing the
> ITabbedPropertySheetPageContributor interface."
> Does this mean the only way to add tabs to the properties for an editor
> is by referencing that editor's specific property contributor ID?
> Yours
> Miro
> Koji Hashimoto wrote:
>> Satyajit,
>> Properties view in the following way. I don't know this is a smart
>> way, though.
>> <propertyTabs
>> <propertyTab
>> category="Advanced"
>> </propertyTabs>
>> </extension>
>> <extension
>> <propertySections
>> <propertySection
>> </propertySections>
>> </extension>
>> return true;
>> return false;
>> Koji
> Original thread: How to add a new tab to the Properties view in a GMF
> editor
Current Time: Wed Sep 03 08:29:23 EDT 2025
Powered by FUDForum. Page generated in 0.30535 seconds
