Home » Language IDEs » Java Development Tools (JDT) » read write file problem
read write file problem [message #148882] Tue, 16 March 2004 17:21 Go to next message
Originally posted by: qwang.cs.concordia.ca
I am a beginner of Eclipse. I write a simple java program
(ReadFile.java)to read the text file. It execute normal in a tranditional
way. However,when I copy it to Eclipse,it give me the message"the file not
found". The text file"test.dat" ,which the program will read is in the
same package fold as the (ReadFile.java). For example, I have the project
named"testfileio",package"rwfile",class"ReadFile.java", textfile"test.dat"
is in the rwfile package also. why this happen? where should I copy the
text file so as that it can be read? your kindly help will really
appreciated.
Linda
Re: read write file problem [message #148890 is a reply to message #148882] Tue, 16 March 2004 18:09 Go to previous messageGo to next message
Originally posted by: newsserver_mails.bodden.de
The file is always looked up in the root package. So you must refer to
"rwfile/test.dat".
Eric
linda wang maundered in <c37ukd$1tg$1@eclipse.org>
> tranditional way. However,when I copy it to Eclipse,it give me the
> message"the file not found". The text file"test.dat" ,which the
> program will read is in the same package fold as the
> textfile"test.dat" is in the rwfile package also. why this happen?
> where should I copy the text file so as that it can be read? your
> kindly help will really appreciated.
> Linda
Eric Bodden
ICQ UIN: 12656220
Website: http://www.bodden.de
PGP key available
Re: read write file problem [message #148902 is a reply to message #148890] Tue, 16 March 2004 19:01 Go to previous message
Eric Bodden wrote in:
> "rwfile/test.dat".
I concur, note that different IDE's might take a different tack than the
current project folder though. I always make a -Dmy.program.folder property
to read if I want to refer to the program folder. If it's not available I
use the current folder. Use the / at all times if possible to remain
compatible.
Maarten
Previous Topic:Occurrances in file of simple text // grep a file?
Next Topic:Strange behavior when Ctrl-Left Click on symbol
Current Time: Tue Nov 04 12:23:01 EST 2025
Powered by FUDForum. Page generated in 0.03563 seconds
