| read write file problem [message #148882] |
Tue, 16 March 2004 17:21  |
Originally posted by: qwang.cs.concordia.ca
I am a beginner of Eclipse. I write a simple java program
(ReadFile.java)to read the text file. It execute normal in a tranditional
way. However,when I copy it to Eclipse,it give me the message"the file not
found". The text file"test.dat" ,which the program will read is in the
same package fold as the (ReadFile.java). For example, I have the project
named"testfileio",package"rwfile",class"ReadFile.java", textfile"test.dat"
is in the rwfile package also. why this happen? where should I copy the
text file so as that it can be read? your kindly help will really
appreciated.
Linda
| Re: read write file problem [message #148902 is a reply to message #148890] |
Tue, 16 March 2004 19:01  |
Eric Bodden wrote in:
> The file is always looked up in the root package. So you must refer to
> "rwfile/test.dat".
I concur, note that different IDE's might take a different tack than the
current project folder though. I always make a -Dmy.program.folder property
to read if I want to refer to the program folder. If it's not available I
use the current folder. Use the / at all times if possible to remain
compatible.
Maarten
FUDForum. Page generated in 0.04053 seconds
