Home » Eclipse Projects » Nebula » Xviewer performances(Xviewer with 25000 roots)
Xviewer performances [message #1486799] Tue, 25 November 2014 04:46 Go to next message
In my application, there is a tree with only two levels but which will contain at least 25.000 roots. What's more, my tree has 14 columns.
I would like to use Xviewer which offers a range of very efficient and interesting functionnalities.
However, the problem is that, in my case, the tree is loading excessively slowly. It looks like SWT.VIRTUAL is not active.
Is the slow loading normal? If so, how can the loading time be reduced?
It appears that, in JFace, there are problems involving trees (not tables) with SWT.VIRTUAL.
Thus, I have the following performance (if I change my tree to a table by removing one level)
25,000 nodes - Tree SWT.VIRTUAL -> > 20 sec
25,000 nodes - Table SWT.VIRTUAL -> > 2 sec
So, if in XViewer the problem with these data volumes stems from the fact that it is a tree, is it possible to change the tree to a table?
If so, how?
Or is there a "table" version of Xviewer?
Thank you.
Pascal.
Re: Xviewer performances [message #1487461 is a reply to message #1486799] Tue, 25 November 2014 16:55 Go to previous messageGo to next message
Hi Pascal,
AFAIK the XViewer is not capable of being lazy. So setting the SWT.VIRTUAL bit will have no effect. If you want XViewer to be virtual capable you have to file a bug against technology/nebula/xviewer.
JFace trees can be virtual. I don't know of any problems with SWT.VIRTUAL on regular JFace treeviewers.
The Nebula Grid widget and the Nebula NatTable widget have the virtual capability and both are table based. However, they lack some of the on-board features of XViewer (but have other features of their own).
I hope this helps,
Wim
[Updated on: Wed, 26 November 2014 03:31] by Moderator
Re: Xviewer performances [message #1489608 is a reply to message #1487461] Thu, 27 November 2014 09:18 Go to previous messageGo to next message
Hi Win,
thanks for your answer.
I will see in more details the Grid Viewer.
Pascal.
Re: Xviewer performances [message #1490598 is a reply to message #1489608] Fri, 28 November 2014 04:16 Go to previous message
We have not publicly announced yet but we are currently working on a
high-performance-feature rich Grid-Framework.
Only problem - it requires Java8 - the underlying control is currently
Nebula-Grid but because the Facade does not impose an UI-Toolkit
information the internal implementation could be fairly everything.
We also don't yet support Tree functions which we'd need someone to fund!
See https://github.com/BestSolution-at/framework-grid
Tom
On 27.11.14 15:18, Pascal Will wrote:
> Hi Win,
> Best regards,
> Pascal.
Previous Topic:Multiple Gantt Charts?
Next Topic:[GanttChart] Removing Sections
Current Time: Sat Nov 22 20:35:30 EST 2025
Powered by FUDForum. Page generated in 0.29324 seconds
