Re: [EMF Forms]Reference feature is not supported when using Dynamic EMF [message #1488135 is a reply to message #1486722] |
Wed, 26 November 2014 05:41   |
I am not sure, whether I understand you issue, could you kindly
elaborate a bit more on what you are currently stuck with?
Best regards
Jonas
Am 25.11.2014 15:21, schrieb yan zhang:
> First I create EMF Model dynamiclly
> But when using the default ViewProvider (in package
> org.eclipse.emf.ecp.view.model.generator) to get View Model, the
> attribute faeture will be contained in the new view model ,while the
> reference feature can not.
> Then I try to implement a ViewProvider myself, I use new
> CustomReflectiveItemProviderAdapterFactory() to construct the
> ComposedAdapterFactory instead of ReflectiveItemProviderAdapterFactory()
> , then the reference feature will be contained in the new view model.
> waiting for help, thanks!
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Re: [EMF Forms]Reference feature is not supported when using Dynamic EMF [message #1489186 is a reply to message #1488135] |
Thu, 27 November 2014 01:52   |
Ok , you can see the following code.
First, I can get a EClass dynamically
public static EClass getEClass() {
* Instantiate EcoreFactory
final EcoreFactory theCoreFactory = EcoreFactory.eINSTANCE;
* Create EClass instance to model BookStore class
final EClass bookStoreEClass = theCoreFactory.createEClass();
bookStoreEClass.setName("BookStore");
* Create EClass instance to model Book class
final EClass bookEClass = theCoreFactory.createEClass();
bookEClass.setName("Book");
* Instantiate EPackage and provide unique URI
* to identify this package
final EPackage bookStoreEPackage = theCoreFactory.createEPackage();
bookStoreEPackage.setName("BookStorePackage");
bookStoreEPackage.setNsPrefix("bookStore");
bookStoreEPackage.setNsURI("http:///com.ibm.dynamic.example.bookstore.ecore");
* Instantiate EcorePackage
final EcorePackage theCorePackage = EcorePackage.eINSTANCE;
* Create attributes for BookStore class as specified in the model
final EAttribute bookStoreOwner = theCoreFactory.createEAttribute();
bookStoreOwner.setName("owner");
bookStoreOwner.setEType(theCorePackage.getEString());
final EAttribute bookStoreLocation = theCoreFactory.createEAttribute();
bookStoreLocation.setName("location");
bookStoreLocation.setEType(theCorePackage.getEString());
final EReference bookStore_Books = theCoreFactory.createEReference();
bookStore_Books.setName("books");
bookStore_Books.setEType(bookEClass);
bookStore_Books.setUpperBound(ETypedElement.UNBOUNDED_MULTIPLICITY);
bookStore_Books.setContainment(true);
bookStore_Books.setLowerBound(0);
bookStore_Books.setUnique(true);
bookStore_Books.setChangeable(true);
* Create attributes for Book class as defined in the model
final EAttribute bookName = theCoreFactory.createEAttribute();
bookName.setName("name");
bookName.setEType(theCorePackage.getEString());
final EAttribute bookISBN = theCoreFactory.createEAttribute();
bookISBN.setName("isbn");
bookISBN.setEType(theCorePackage.getEInt());
* final Add owner, location and final books attributes/references
* to BookStore class
bookStoreEClass.getEStructuralFeatures().add(bookStoreOwner);
bookStoreEClass.getEStructuralFeatures().add(bookStoreLocation);
bookStoreEClass.getEStructuralFeatures().add(bookStore_Books);
* Add name and isbn attributes to Book class
bookEClass.getEStructuralFeatures().add(bookName);
bookEClass.getEStructuralFeatures().add(bookISBN);
* Place BookStore and Book classes in bookStoreEPackage
bookStoreEPackage.getEClassifiers().add(bookStoreEClass);
bookStoreEPackage.getEClassifiers().add(bookEClass);
return bookStoreEClass;
Then I use the returned EClass to get a UI component by EMF Forms.
EObject dummObject = EcoreUtil.create(bookStoreEClass);
final ViewModelContext vmc = ViewModelContextFactory.INSTANCE.createViewModelContext(
ViewProviderHelper.getView(dummyObject, null), dummyObject, new DefaultReferenceService());
render = ECPSWTViewRenderer.INSTANCE.render(content, vmc);
The generated UI component should contain three kind of controls for three feature of bookstore, but it only contains two (owner and location, but not books), you can see screenshot (result.png), but the expected result should be like expected.png.
Attachment: result.png
(Size: 27.46KB, Downloaded 167 times)
Attachment: expected.png
(Size: 27.44KB, Downloaded 158 times)
[Updated on: Thu, 27 November 2014 01:59] by Moderator
Re: [EMF Forms]Reference feature is not supported when using Dynamic EMF [message #1489395 is a reply to message #1489186] |
Thu, 27 November 2014 05:28  |
the property type of containment references is by default "None". In
static EMF, this is set in the gen model. It has to be editable to be
shown in the UI.
Best regards
Jonas
Am 27.11.2014 07:52, schrieb yan zhang:
> First, I can a EClass dynamically
> Then I use the returned EClass to do the following things.
FUDForum. Page generated in 0.09069 seconds
